Blow Off valve
Old Dec 1, 2003 | 12:13 PM
Silvercar's Avatar
Question Blow Off valve
I have a AEM intake and a Blitz bolw off valve . And also I got the HKS grounding kit. And the car keeps stalling. Whats the problem?
Old Dec 1, 2003 | 12:21 PM
midwestmonster's Avatar
Is your BOV venting to the atmoshpere? If so, that's your problem. Without some fuel management such as a S-afc II, the car won't run right if you're venting.
Old Dec 1, 2003 | 03:36 PM
Silvercar's Avatar
That sucks. It does 100% vent but my friend also has the same set up and his EVO is running fine.
Old Dec 1, 2003 | 03:40 PM
bishiboy's Avatar
I was having occational stalling issues too.
Once I got my HKS S-AFR everything is fine.
It has an Idle gain controller, basically a fuel controller for the idle circuit. Just turn it until the idle smoothes out (+ or -). I had the idle AFR checked when I dyno'd and it was ok.
No more stalls.
Old Dec 1, 2003 | 03:56 PM
masterevo's Avatar
Venting is awesome, but not with the stock ECU. If you want to vent, might as well wait till u are ready to upgrade ur turbo and go for a full standalone. But as far as venting on a stock ecu with the MAF sensor, it is not going to work perfectly and I heard alot of bad stories. I wanted to vent too, but too much side affects. Go for a the greddy type s and the aem intake. That is what im going to do. Anybody around here has that setup? Please let me know how it sounds. Thx...Peace outside!!!
