Full-Race / BorgWarner EFR
Old Nov 2, 2010 | 01:47 PM
Silk's Avatar
This level of innovation is outstanding!
Old Nov 2, 2010 | 02:08 PM
n2oiroc's Avatar
it is, but results are what matters.
Old Nov 2, 2010 | 02:12 PM
ClaudioEvoX's Avatar
i want one of those!!! :-)
Old Nov 2, 2010 | 02:15 PM
hokiruu's Avatar
I'm also eagerly awaiting results. A friend of mine is getting one for his 06 Subaru to test next month.
Originally Posted by black95tt
I just read about these on Supraforums. Some hush hush preliminary testing on a 2JZ showed that a 68mm housing developed positive boost by 1800rpm reaching 25 psi by 3800rpm! That is impressive. I also love the idea of fully integrated WG, BOV, boost solenoid valve and speed sensor. That is really cool stuff.
Keep in mind that according to Geoff, the integrated diverter valve will not be available for Evo applications unfortunately. Not that that should be a major strike against the other benefits of running one.
Old Nov 2, 2010 | 02:21 PM
Chris@nolimitmotors's Avatar
Originally Posted by n2oiroc
any idea if that downpipe on the ts evo kit will clear a/c?
No it wont. It made to be ran on cars with no AC.
Old Nov 2, 2010 | 03:51 PM
03whitegsr's Avatar
Snaked some T25 sized EFR turbocharger pictures off the web...
Old Nov 2, 2010 | 04:03 PM
n2oiroc's Avatar
i have a 3" radius 3" mandrel bent stainless tube just for the occasion!
http://www.atpturbo.com/mm5/merchant...egory_Code=STL
Old Nov 2, 2010 | 04:04 PM
hokiruu's Avatar
Nice find! It kind of makes me wonder why someone hadn't done this type of thing sooner.
Old Nov 2, 2010 | 04:10 PM
03whitegsr's Avatar
FWIW, a bend that is 1:1 Bend Radius to Outer Diameter ratio doesn't flow very well at all. You want to be above 1.5:1 if at all possible, making a 4.5" bend radius the minimum desirable on a 3" tube.
Old Nov 2, 2010 | 04:12 PM
n2oiroc's Avatar
ill run the biggest radius i can, im not expecting to get a 6" radius in there, but i guess there is only one way to find out.
Old Nov 2, 2010 | 07:35 PM
JC evo1's Avatar
it is, but non-biased independent results are what matters.
edited
Old Nov 2, 2010 | 07:52 PM
Strm Trpr's Avatar
From what I read the integrated diverter valve is on all compressor covers.
There is a plate that is used to seat the plunger if the diverter valve is not desired.
I think what you meant is that the Evo EFR series turbos can not use the internal wastegate turbine housings because the diffuser is extra long for the internal gate and a 3" O2 housing will run into the A/C Compressor.
This is where I read the above info. http://www.full-race.com/articles/bo...fr-turbos.html
Old Nov 2, 2010 | 11:41 PM
discopotato03's Avatar
Some of the styling reminds me of the 80's era Volvo and SAAB OE turbos . Some of them had a throttle closed recirc valve set into the compressor housing . I think Mitsy may be the ones I'm thinking of - possibly TD04HL's .
The IW turbine housings are different in that you can see all of the turbine outlet from the housings one , rather than a big V band hole and half of each .
Old Nov 3, 2010 | 12:35 PM
R/TErnie's Avatar
the 7670 has my eye.
Old Nov 3, 2010 | 01:33 PM
Ludikraut's Avatar
7670 looks really nice, but I'd be worried that it would fall off too soon up top. My current setup, a 50 trim, starts falling off at about 7K. I don't think the 7670 would be able to hold on much longer - maybe another 500 RPM or so. Will be interesting to see how easily it spools, might be a case of having my cake and eating it too. It'll certainly outflow a 50trim, and if it outspools it as well....
l8r)
