using aftermarket valve springs with stock retainers
Old Nov 3, 2010 | 10:58 AM
42revoincali's Avatar
is this ok to be done?
in example, gsc beehives and stock retainers.
Old Nov 4, 2010 | 03:15 AM
MR. EVO MR's Avatar
why? especially when everything is opened up, plus you want to be safer, no?
Old Nov 4, 2010 | 04:48 AM
EvoJoeIX's Avatar
Yes you can use the gsc bee hive springs on stock retainers. Lots of people do it
Old Nov 4, 2010 | 07:12 AM
EVO IXMR's Avatar
I would do a full kit for added safety and you'll have the safety of revving the life out of it without having valve float or flutter..
Old Nov 4, 2010 | 07:56 AM
GG06MR's Avatar
Yep. I have the beehives with stock retainers, and I personally recommend the stock retainers, since at least some titanium retainers are made from inferior material and are therefore a wear item.
Old Nov 4, 2010 | 07:58 AM
evolution2186's Avatar
Very valid point. Stick with a known manufacturer with proven product and never short cut. You will save money doing it proper in the first place in the long run.
Old Nov 4, 2010 | 08:01 AM
EVO IXMR's Avatar
It depends on what kit you choose I would only use supertech's ,gsc,or kiggly's they make the best kits available..
Old Nov 4, 2010 | 10:19 AM
i dont plan on revving the crap out of my motor or even tracking it even once in its lifetime.
hopefully stock retainers will be ok.
Old Nov 4, 2010 | 12:33 PM
Evotech8's Avatar
FYI...the stock retainers are just as light as the titanium ones.
I would just reuse the stock ones but with 'new' oem retainer locks.
Old Nov 4, 2010 | 12:43 PM
L@Ncer06's Avatar
that will work fine no problem
Old Nov 4, 2010 | 01:59 PM
scheides's Avatar
EvoM Moderator
GSC's 5039 kit was *made* to be run with the stock seats/retainers. I put like 20k miles on mine, rev'd the stock bottom end to 8200 on Kelford272's. For the money on the stock bottom end, it cannot be beat!
Old Nov 4, 2010 | 02:56 PM
Teal2nnr's Avatar
Honestly? good god man retains are cheap as hell....you REALLY want to stick with stock retainers? not calling you cheap...but if the shoe fits......
Old Nov 4, 2010 | 03:02 PM
well the thing is that its not me, its the shop im going through recommends stock retainers, i was just skeptic.
i wanted opinions.
Old Nov 4, 2010 | 03:08 PM
GG06MR's Avatar
Honestly, titanium retainers are a pretty pointless mod unless you're building a purpose built track car that'll be spending most of it's time at 7K+ rpm.
i wanted opinions.
If you have to doubt whether or not to upgrade..........upgrade.
