New CEL ON NOW!!! Damn...
Old Dec 1, 2003 | 06:16 PM
TRDHarrier's Avatar
Angry New CEL ON NOW!!! Damn...
I am running Dynoflash, CUsco Oil Catch Can, Custom Ground Kit, HKS DP, UR 3" High Flow Cat, and HKS CB. I have been running with this for 9000 miles with no CEL. I also have a headunit in my car which I removed and placed aside for probably a couple months. I removed the HU and added on a silencer since my father needs a car to drive during his business trip to the US. It'll be safer w.o a HU and quieter without a silencer. It's much quiet but suddenly, the CEL is on. I believe it might be the cause of the silencer pushing back some of the exhaust into the O2 sensor probably. The UR Hi Flow Cat was on the car for a few thousand miles with no CEL. Will it be the silencer? The HU shouldnt do aything right?
Old Dec 1, 2003 | 11:44 PM
TRDHarrier's Avatar
BUMP BUMP
Old Dec 1, 2003 | 11:46 PM
BadBoyBeltran's Avatar
Get the CEL decoded.
Old Dec 2, 2003 | 06:07 AM
SuperchargedGTZ's Avatar
what i dont understand is...if you plan to mod your car, WHY dont peps get a scanner/code reader. This is probably the best thing that you can buy for your car if you plan on modding your car. YOu can tell what your car is doing and if you throw a code...you can see what code it is...
here is one place to get them...
http://www.levineautoparts.com/autcodscan.html
Old Dec 2, 2003 | 06:26 AM
95GSXtoEVO8's Avatar
You could also go to pep boys or auto zone, whatever large parts dealer in your area, and have them read the error codes for free.
Old Dec 2, 2003 | 06:55 AM
BoostedMike's Avatar
best post i've seen for quite some time!
Old Dec 2, 2003 | 10:12 AM
QuantumEVO's Avatar
Or how about these which act as scanner AND gauge array; now available for EVO:
http://www.psi3.co.uk/mitssingle.html
> SINGLE DIN FITMENT
> VEHICLE/ECU AUTOMATIC IDENTIFICATION
> SUPPORTS 16 PIN OBD CONNECTOR CARS
> LIVE DATA MONITORING (display layout can be custom configured)
- Battery voltage - Volts
- Engine Speed - RPM
- Vehicle road speed - MPH or KMH
- Coolant temperature - Degrees C
- Intake temperature - Degrees C (This is not charge temp.)
- Fuel injector pulse width - Milliseconds
- Ignition point - Degrees BTDC
- Knock correct - Degrees (Ignition Timing)
- Lambda air/fuel ratio
- Throttle position - %
- Air flow meter mass - Grammes Per Second
- Boost pressure - Bar (additional sensor required)
- Oil Pressure (additional sensor required)
- Oil Temperature (additional sensor required)
- Exhaust Gas Temperature (if available from ECU)
> READING OF CURRENT AND HISTORIC FAULT CODES
> ECU/FAULT CODES RESET
> SHIFT LIGHT CONTROL WITH ADJUSTABLE SETPOINT (LAMP NOT SUPPLIED)
> EXTERNAL ALARM/SHIFT LIGHT OUTPUT
> USER ADJUSTABLE ALARMS MONITORING
- Battery voltage low
- Battery voltage high
- Boost pressure (additional sensor required)
> WATER INJECTION/NITROUS CONTROL
> RECORDS PEAK READINGS (USER RESETABLE)
- Engine speed - RPM
- Boost Pressure - Bar (additional sensor required)
- Road Speed - MPH or KMH
- Coolant Temperature - Degrees C
> CLOCK
> USER SELECTABLE OPTIONS:
- BAR or PSI
- MPH or KMH
- Degrees C or Degrees F
- Boost ECU or Boost External
- Lambda or AFR
> MPH TO KPH
> NOTE: Unit features may vary according to specification of vehicle ECU supplied data.
Mark
www.Quantum-Racing.com
Old Dec 2, 2003 | 10:17 AM
NYEVO8's Avatar
very cool item above, but do you have to be a scientist to install or is it ecu plug and play?
Old Dec 2, 2003 | 11:07 AM
QuantumEVO's Avatar
It plugs into the OBD2 socket. That's it.
When you add more sensors down the road (also available; they use Defi sensors for the kit), it plugs into the back of the unit as well. No wiring.
The unit itself is a single DIN model and therefore installs like a radio.
Mark
Old Dec 2, 2003 | 01:12 PM
> SINGLE DIN FITMENT
> CLOCK
- BAR or PSI
- MPH or KMH
- Lambda or AFR
> MPH TO KPH
Mark
How much is that one.....
Old Dec 2, 2003 | 01:40 PM
Karash's Avatar
how much is that Can I buy one from you?
Old Dec 2, 2003 | 01:56 PM
Or if you don't want to spend that much, you can a pocketlogger. http://www.pocketlogger.com/index.php?pid=plobdii
it will get engine codes and also record other valuable tuning info like timing, 02, etc. It's like under $200.
QuantumEVO's Avatar
I am the North American distributor for those, but you can get them from Ralliart soon as well if you want to pay their price.
The single DIN version is just now shipping to me in the first batch for EVO8. The main unit (everything you need to pull codes, reset the ECU and read stock sensors) is $478 with free shipping.
Mark
Old Dec 2, 2003 | 07:15 PM
EvoJimbo's Avatar
Mark what about all teh other sensors...do you have those also.
Old Dec 14, 2003 | 02:05 PM
AltezzaRoku's Avatar
ya..... can you get the sensors?!!
