whistleing sound when boost goes more than 10 psi
Old Nov 6, 2010 | 10:36 AM
lancerjdm2.4's Avatar
hey guys i'm not an evo owner but my friend is....he have an fp red turbo with an ams intercooler , injen pipping and tial bov...he ask me to come to the forum to ask about a weid sound that he listens to when he press the gas pedal and boost start to come up...it is like a whistle (kind of the sound a supercharge produces)...i thought about boost leak but he said the boost gauge shows 22 psi and that's what he is running so according to the gauge there is no boost leak...any comments on these????
Old Nov 6, 2010 | 10:39 AM
i don't know if this also could affect but he has skunk 2 cam gears...hks exhaust....
Old Nov 6, 2010 | 10:41 AM
03evo8racer's Avatar
Probably just the sound of the turbo.
Old Nov 6, 2010 | 10:44 AM
gunhaha's Avatar
Boost leak!
The gage won't give any indication of a leak as the turbo will just make up and run to that 22 psi setting. Even a stock turbo will still get you to 30 psi, if that is your target, even with a boost leak; it will just work harder to get there (bad/overspin).
Boost leak test...it only takes like 30 min.
4RETECH's Avatar
Building pressure doesn't mean you can't have a boost leak.
Do a proper boost leak and you will be surprised at what you thought was a sealed system.
Old Nov 6, 2010 | 10:46 AM
D-VO's Avatar
That could be a couple of things. Like: normal turbo spool, blades hitting the housing, exhaust leak past the turbo, obstruction in the exhaust. Also, what kind of boost controller is he using?
Old Nov 6, 2010 | 10:53 AM
EVO IXMR's Avatar
Its the nature of the fp red they love to whine loud almost sounds like a fire truck.
Old Nov 6, 2010 | 10:55 AM
i know the fp red sounds hard and i love the sound but this is not normal...my ralliart is turbo to and when he did that sound once it was boost leak...but in my case it didn't showed any boost in the gauge...i think it also depends on where you have your gauge connected...thank you guys
Old Nov 6, 2010 | 11:00 AM
EVO IXMR's Avatar
Then possible its your t.b shaft seals they make this type of sound..My suggestion is do a proper boost leak test again and listen carefully for the tiny leaks..One my thing check the turbo housing it's self if the o ring goes bad in it can also whine..
Old Nov 6, 2010 | 11:09 AM
mt057's Avatar
Do a boost leak test to be sure, but my 80mm fp red almost sounds like it is a super charger. It happens right at the onset of boost until about 5 psi. It goes wwhheeee...
Old Nov 6, 2010 | 11:59 AM
jusa4bngr05mr's Avatar
Yep my whistles like crazy while at idle, up to 10psi
Old Nov 6, 2010 | 01:15 PM
SLO-EVO's Avatar
if it isnt the normal sounds, your jpipe could be loose.
Old Nov 6, 2010 | 01:29 PM
brenner's Avatar
mine made a craZy whistle when my jpipe seal was shot
my $ is on a boost leak from there
Old Nov 6, 2010 | 01:32 PM
mhezz13's Avatar
+1 on boost leak test.
happened to me before, good thing it was just a loose clamp
Old Nov 6, 2010 | 05:32 PM
thank you guys...we'll be doing some tests between tomorrow and monday...the prob is that we don't have much time cause we still are @ college and proffesors are KILLING us... ....promise we will let you know the results...
