Looking for answers for what makes a turbo spool quickly.
Old Nov 8, 2010 | 08:18 PM
therunningskier's Avatar
Well this may be a noob question but I haven't been able to find anything searching the forums. Well nothing that answers the question with any facts, or reasons why it spools more quickly. I mean obviously I know a big giant turbo will spool later than a smaller turbo, but what can you do to make a giant turbo spool more quickly?
What factors affect a turbo's rate of spool. Or when it starts to fully boost. I know airflow plays a factor, the size of the turbo and wheels, ball bearings, ect ect.
So, what can you do to make a motor/turbo that'll spool as quick as possible?
Any insight would be great.
Again looking more for why a turbo will spool quicker rather than just a dyno plot of a fp red spooling quicker than a GT42R...
Old Nov 8, 2010 | 08:25 PM
ElectrIX Blue's Avatar
ported ex mani, ported head, bigger intercooler, uicp+licp, larger o2 housing, ported head, all of these helps the turbo to spool more quickly.
Old Nov 8, 2010 | 08:30 PM
How? I mean more air flows through, but is that all it is?
Old Nov 8, 2010 | 08:31 PM
What about a ball bearing turbo vs not...
Old Nov 9, 2010 | 03:11 AM
ALSTAR's Avatar
Get some more air flowing towards the intake.
Check for leaks.
Old Nov 9, 2010 | 03:13 AM
MR. EVO MR's Avatar
less psi wga
Old Nov 9, 2010 | 03:23 AM
MattC28's Avatar
buy a different turbo that spools faster
Old Nov 9, 2010 | 06:30 AM
GG06MR's Avatar
Originally Posted by ElectrIX Blue
ported ex mani, ported head, bigger intercooler, uicp+licp, larger o2 housing, all of these helps the turbo to spool more quickly.
All but the bigger intercooler. A bigger intercooler will increase cooling efficiency, but you're going to see some type of reduction in spool.
Old Nov 9, 2010 | 09:01 AM
That's not quite what I am looking for. Same turbo, what can you do to make it spool more quickly.
Old Nov 9, 2010 | 09:02 AM
anything a bit more technical than more air. Or is it really just that simple...
Old Nov 9, 2010 | 09:15 AM
BLKCarbonEVO's Avatar
Bigger FMIC will reduce spool-up.
MIVEC helps spool, high ramp rate cams increas spool and most of what has alrady been said. Anti-lag helps too Reduce backpressure = increas spool
Mikey
Old Nov 9, 2010 | 10:14 AM
38six's Avatar
The answer I believe you are looking for, deals w/ changing the way exhaust flows from the cylinder.
[LIST][*]Twin Scroll Turbo[*]smaller hotside(turbine housing)[*]smaller exhaust manifold (diameter & or runners) [*]cams & tune
note: twin scroll is the only solution that does not affect the total power out put of the turbo. I hope this helps.
Old Nov 9, 2010 | 11:15 AM
ok maybe this is another dumb question, but, how does a twin scroll better use the exhaust flow from the cylinder?
Is this the same way say a jet engine using 2 stages in the turbine section as opposed to 1 is more effecient and creates more power?
Which turbos are twin scroll as opposed to not twin scroll.
Old Nov 9, 2010 | 11:17 AM
compscibOi's Avatar
large volumes of air that are moving fast...
Make the most amount of air move the fastest... that is what will spool a turbo quick.
Smaller turbos, larger exhaust manifolds, better flowing manifolds, ball bearing turbos vs journal bearing.... etc etc etc...... the list goes on...
Old Nov 9, 2010 | 11:19 AM
norcalSRTrida's Avatar
EGT's and cam profile.
