What size gap for plugs with spoolin up cop??
Subscribe
Nov 12, 2010 | 07:13 AM
Whats everyone gaping there plugs with a spooling up cop with around 550 whp??I had the plugs gaped to a tight .19 to stop blowout with the stock coils no (dli) but know that I have the cop people are telling me to open up the gap to burn the fual more proper..Suggestion???
Reply 0
Nov 12, 2010 | 07:16 AM
.22 you should be good there
Reply 0
Nov 12, 2010 | 07:17 AM
Reply 0
Nov 12, 2010 | 07:42 AM
Quote: .22 you should be good there
Thats what I was thinking to set them at..I wounder if I can get away with them at .24 ??..
Reply 0
Nov 12, 2010 | 09:34 AM
i run my buschur COP at 24
Reply 0
Nov 12, 2010 | 09:37 AM
.24 and the car was stumbling in every gear by 5000 rpm's, problem solved after Spoolinup COP.
Reply 0
Nov 12, 2010 | 10:37 AM
I'm making 686 on Cbrd mustang Dyno and I was at .22 gap on the okadas and stock plug wires and 38psi and had no issues. I have the spoolin up kit for back up when I get retuned for 45+psi. So I would hope the spoolinup cop is better than the okadas, so that means you should be able to run a bigger gap.
Reply 0
Nov 12, 2010 | 12:26 PM
anyone else??????????
Reply 0
Nov 12, 2010 | 12:41 PM
make it as big as possible without having spark blowouts.
Reply 0
Nov 12, 2010 | 01:01 PM
You guys run some big gaps, I only run .026, wow!
Reply 0
Nov 12, 2010 | 01:05 PM
I ran .030 with my spoolinup COP on my evo8 with a BBX, ported head and all the fixins at 33psi, no problem.
Reply 0
Nov 12, 2010 | 01:06 PM
Why not start big and then lower until your not getting blow out?
Reply 0
Nov 12, 2010 | 01:17 PM
we recommend IR plugs gapped from .22-.26... depending on fuel/boost pressures!
cb
Reply 0
Nov 12, 2010 | 03:12 PM
I'm running the ST noncdi and plugs gapped to .028. Haven't had a problem yet. I'd start around there and gap them down until you don't get blowout.
Reply 0
Nov 12, 2010 | 07:24 PM
Please specify what plugs, what boost level, and what fuel. As Tweaker above states, on pump, at less than 30#, and on BR7ES, or BPR8ES, I would try for .028" which is just about ideal. If it sputters... then close the gap back down to .027-.026". The COP ignitions should permit the wider gaps without fouling.
Reply 0
