I just ordered a 2.1l oil question?
everyones different but i followed http://www.mototuneusa.com/break_in_secrets.htm and used non synthetic vr1 for 500 miles and new motor has 10-15psi more compression then my first 2.3
i didnt magically get more compression for nothing. break in is crucial. you must rev the motor to 6500-7k and let off in gear , dont shift.. it will break the motor in properly. do that a dozen times, then do the same thing to 4500-5k. dyno break ins different but im just going by doing it on the road.
also i used **** oil for the first time breaking it in this time around and drained it in 15 miles and it still managed to burn up my fp blacks thrust bearings so be very cautious to what oil you use if you have the steel on steel thrust bearing fp black/red.
when i read that i was shocked.. and ya it was pure black in only 10-15 miles of driving.. it shouldnt even be allowed to be sold. same goes for advanced auto oil.. absolute garbage as well.
i drained it in 10-15 miles jackass. after reading the back of autozone oil i wont even put in my lawn mower now. the back of it reads "its not for engines built past 1927 because it contains no detergents or additives"
i agree about a brake in oil. i ran a 10w40 non syn for like 100 miles. then went to 15w50 and have had good results with my motor so far.
im not the jackass if your thinking the motor don't give a crap about what oil is in it and its based off of what the turbo likes..............................
i know the motor cares, but it sure as hell isnt gonna do much when you're draining it in 10-15 miles. i run amsoil 20w50 premium synthetic and brad penn 20w50 normally.
if you think i run autozone oil 24/7 then you're out of your mind. and i was dumb for even putting the **** in there to begin with so you dont have to remind me.
I dont get it.. 1st you say the engine will take ANY OIL that the motor doesnt give a sh*t..
then you say you wouldnt use sh*t oil in your lawnmower.. Im confused..
did you read what i said tho? i changed it in literally 10-15 miles. if an oil can break down that fast it shouldnt even be allowed to be sold at all.
you're thumbing this up yet you do realize there are GOOD oils that are perfectly fine for a 4g63 yet the FP red and black will die on.. do you understand this?
Therefore my statement does make sense.. you do have to work around what the turbo likes and wants unless you want to remove the turbo every 50 miles.
that is why i said what i said.
Mike
so you're saying you wouldn't trust any oil that will jeopardize the red/black period in a engine right? if the turbo cant handle it then it shouldnt be used right? if so i agree..
honestly i normally would have never used autozone or cheap oil, but my friend online told me to since i was gonna drain it so quick.. so its my fault for using the garbage oil and i definitely felt the consequences of it.
Mike
this stuff has some of the best rated tests Ive researched on oils, and ive looked at around 20 different oil reports from blackstone
its the old Kendell oil, which is as good as Amsoil any day of the week.
