ETS Limited Edition Titanium Short Route Piping Kit!
Old Nov 23, 2010 | 05:12 PM
JohnBradley's Avatar
Don't do a BOV at all on the upper and move it to the LICP. Way prettier that way since you dont have to use a ***** size BOV.
aaron
kiadaw's Avatar
Hi Michael from ETS,
A little off topic, but can you answer my question on the ETS LP2 LICP?
I was going to order the ETS LICP which have overall good review from fellow evo driver here.
However, I can't help but notice the 2 supporting brackets from the stock pipe (which I assume to be screw mounted for stability) is missing in the ETS pipe? Would that be an issue, how does it then mounted? Does it uses the T-Bolt clamps (whatever they means) in the product specification as mounting.
Specifications
Full Mandrel Bent 2.5" Piping
Stainless Steel T-Bolt Clamps
4-Ply Reinforced Silicone Couplers
Cheers.
Old Nov 23, 2010 | 05:14 PM
However, I can't help but notice the 2 supporting brackets from the stock pipe (which I assume to be screw mounted for stability) is missing in the ETS pipe? Would that be an issue, how does it then mounted? Does it uses the T-Bolt clamps (whatever they means) as mounting.
"Stainless Steel T-Bolt Clamps"
Cheers.
Its rigid enough that when its all coupled up its fine. T-bolt is a style of clamp.
Old Nov 23, 2010 | 05:56 PM
AboodsEvo's Avatar
sexy time! (borat)
Old Nov 23, 2010 | 06:39 PM
n2oiroc's Avatar
aaron
Old Nov 23, 2010 | 06:44 PM
EvoDan2004's Avatar
can we get a weight savings of the aluminum UICP VS the titanium UICP plz????
Old Nov 23, 2010 | 08:00 PM
RockmanX's Avatar
burn the whole pipe and i may consider getting one but would love to see it first.
Old Nov 23, 2010 | 08:13 PM
EVO IXMR's Avatar
Originally Posted by n2oiroc
Or better yet a fleshlight..
Old Nov 23, 2010 | 08:15 PM
zac5's Avatar
look pretty badass. how about the weight differences?
Old Nov 23, 2010 | 08:42 PM
Gary@MellonRacing's Avatar
looks great
Old Nov 23, 2010 | 08:43 PM
redleg225's Avatar
The weight difference is negligible and pointless. Unless you're trying to outrun the BAD BISH you're fine with any UICP.
This is just BALLER.
Old Nov 23, 2010 | 09:52 PM
zcchenCT9A's Avatar
Originally Posted by sLUg_
f**k right after I order mine...
exactly my situation too.. Can we return and swap for the new ones???
EvolutionVIIIrs's Avatar
i also vote for a fully burnt pipe..
And this i must say, IS GORGEOUS!!
ETS Michael
ExtremeTurboSystems.com – WA
14
Jun 29, 2012 03:49 PM
ETS Michael
10
May 26, 2011 01:58 PM
Gary 805
Jan 8, 2011 07:01 AM
OverBoostedEvo
Oct 13, 2010 08:47 PM
