Trans help!
You know when I was cleaning the bushings I did move the lower most linkage but I don't think I "snapped" it correctly into its place. The shifter was really stiff and when I drained my transmission fluid it was all gunk. This was the first time I tried Amsoil transmission fluid and it was worse than the Pennzoil synchromesh. I have pennzoil in it now and everything is working properly except for reverse. I did take the center console apart but I didn't have any luck there either.
This has nothing to do with your tranny/clutch issue,,, but i would mention that the fluid you are using syncromesh is not enough for lubricating the gears the fluid is great on syncros but not gears it does not have enough film strengh, you are better off using Diaqueen i will let you do your own research on that and won't spoon feed you.
OP you will not have an issue with syncromesh EVER
like Shep told me one time , lets measure the internals of that tranny and compare it to one that uses MTL and you will see a difference.
dude we can care less if your tranny has 300k, but you wont tell me and the smart people in this forum that syncromesh will have better gear lubricity and shear capacity than redline MTL or ASMOIL MTG, there is no freging way, iam sure if you dont have more than 330whp and you granny shift all the time then you may be ok, but if you drive the evo like it was meant for you need to do better than that.
I have used synchromesh in a lot of clutch jobs I have done because I don't want to run the risk of using AMSOIL since it isn't working for me. I am a dealer through AMSOIL and I know what these fluids are capable of but unfortunately for me ever since I switched over to their transmission lube, my tranny has been rebuilt not once but twice. All of the cars I have used synchromesh in have been running strong. I don't have an issue with AMSOIL but personally it hasn't worked for me. So no need to spoon feed me kind sir.
Can you get the car into gear with the car turned off ? If not, then you have either a linkage issue or something wrong inside the tranny. If you can get the car into gear while the car is off, but not when the car is on, then you likely have a clutch issue. Good luck
There is something else wrong then....If you cannot get the car into gear while the car is off, there is either something internal or your shift linkage is the culprit (adjusting the pedal is not the answer). My guess is you f'd up the linkage adjustment, so start there...Good luck
You pulled the cables from the trans linkage and then tried to row the gears from the shifter in the car and couldn't? The shifter should go anywhere at that point as it is not connected anymore
Not from the shifter I didn't. I actually went into the engine bay and tried manually shifting the trans...all the gears go in except 2nd and reverse.
well to add my 0.02 ive got an 03 evo 8 i currently have about 80k stock trans never rebuilt, and since ive owned the car since 39k, ive always put in redline mt 90 wit shockproof for fluid....never an issue a little notchy till u drive a mile or so but the car drives that way till its fully warm....u can try that my tuner recommended that fluid and so far im good, same with my transfer case no death wine, a couple of launches on the car, and 385 whp in 107 weather....id say try that fluid get some new underhood bushings and base shifter bushings....that should help
