Need Specs: Long Rod 2.0 Build
Old Nov 28, 2010 | 03:46 PM
Evokid03's Avatar
Hey guys, i need some help with spec on doing a 2.0 Long rod motor.
Friend of mine is building his motor and i honestly have no idea lol.
I need the specs on the short block
What Rods / Length?
What Pistons?
What Crank?
Im mainly confused on the pistons, is there a part number or a website u can directly lead me to ordering a set of 2.0 long rod high compression pistons?
Old Nov 28, 2010 | 03:55 PM
Jmelocik@Spec-Ops's Avatar
Brain cramp!
Josh
Old Nov 28, 2010 | 03:57 PM
Evokid03's Avatar
^^ What lol?
Old Nov 28, 2010 | 05:22 PM
Silk's Avatar
156 MM rods with stroker pistons. stock crank
Old Nov 28, 2010 | 05:37 PM
Evokid03's Avatar
Got it Thanks
Old Feb 20, 2011 | 03:24 PM
kelvinTME's Avatar
Standard 2.3 litre stroker pistons?
Old Feb 20, 2011 | 03:47 PM
sho669's Avatar
Yes. 156mm rod and the piston has a comp hight of 1.13 which is what the 2.3 pistons are.
Old Feb 20, 2011 | 03:56 PM
JohnBradley's Avatar
But the dish is to deep on an off the shelf 2.3 piston unless you grab the 10:1 JE and I believe there is a Wiseco offering in roughly the same compression range that ends up around 8.5 or 9.0:1 without doing a custom piston.
edit-
Neither have a high compression option. Throwing them in as an off the shelf would drop the compression from 8.5 in the case of the JE to 7.96 and 9:1 wiseco to 8.06 with a .040 gasket. If you want a normal compression ratio it will need to be "custom" which would send me to Wiseco, both for product and lead time.
Old Feb 20, 2011 | 04:18 PM
Looks like Manley will have an off the shelf piston before too long.
617000C-4 85 STD 156 88 1.130" -12 47 / 43 8.5 / 9.0 Dish 298 46850-4
louiesevox
10
Oct 29, 2017 06:56 AM
SBR INC
Nov 26, 2016 07:39 AM
BadassEvo8
Apr 22, 2015 09:56 PM
Evosteined
Oct 16, 2007 07:43 PM
yikez
31
May 23, 2007 02:57 PM
