is it worth the risk of buying a used twin disc to rebuild?
Not to jack the OP's thread but Aaron I have an important question and I feel the rest of the community would benefit if it was public:
I was told that Exedy triple clutch is harder on the transmission then say a twin. Is this true? and If so, how much worse is it on the transmission? Ive experienced my clutch slip already, so i know im reaching the limits on my twin.
and your setup with the exception of the 2.3(im doing a lr 2.0) is exactly what im in the process of
in most power goals a triple is to much the exedy twin can hold a ton of power and easier on the foot. Mine is used on I bought then sent it to strictly modified for a complete overhaul to make it brand new status 630 for all new parts dics pressure plate etc. I bought the clutch off ebay for 380 shipped so 1010 for a brand new in the game clutch installed rode on easy for 1000 miles then taken to dyno to lay down 584whp and not even consider slipping more power to come I say buy use send to honest shop like strictly modified let them fully inspect and rebuild with all parts you need
Im glad to know that my clutch "wont think about slipping" at 535tq.
Now, OP. I am in the same boat. I bought a used twin, rebuilt it and its been awesome at 515/400 on pump. Im now thinking of going bigger, and have been debating if the twin will hold more power...or if i need to upgrade to a triple. Some say it will hold it fine, others say it will slip first dyno pull. Id say be safe and go for the triple.
I did 600tq on the twin, but on a long trip it started to slip pretty bad. I'm not sure whether that was abuse related or just the engine getting hot during the 500 mile trip. Other then that long trip, ive never experienced it acting up before really. Someone told me i could have glazed over the clutch from cruising with it at 80mph~ for long periods of time.. dont know how much truth to that is.
Dude why do you even bother replying to a thread that you know NOTHING about? Have you ever driven a triple disk? Or driven a twin? The triples pedal feel is no different than the twin. so no, your "workout city" would not come into play.
The only way it could be motor related is if the oil seal case was leaking oil past the seal and i dont think that happened, because i didn't smell any oil.
according to AMS site exedy twin ratings
Max Torque Drag - 455
Max Torque Street/Road Race - 563
Be warned by me if you getting close to our builds its pricey LOL. Had i known it was going to cost this much in the end I would have be like woah no way but once you need deep in the situation you have to roll with the punches and pay what comes up in front of you. my tuning is not done yet. once i add stronger spring ill be in 600 like tscompusa just hope low boost can be set between 26-30 psi for my pump gas map and all will be good
what three exedys? all evos? were some HD and some not? all these factor into how the clutch pedal will feel. i have driven many clutches including exedy triple carbons and tiltons and i have to say the easiest clutch to drive on the street was the carbon, draw back was that it tore it self up daily driving as they are really ment only for racing, the tilton was crap for DD but sweet at the track as thats what it was ment for. SO far the best clutch i have driven is my exedy triple cerametalic with the clutch fork stop(helps when you have to have some more spirited driving) easy on the leg when cruising around town and easy to launch on the 1320. Before its asked my car also has over 500whp/397tq and has achieved low 10 sec 1/4 mile times on 93 pump. I have tested this clutch in many conditions and taught my wife how to drive stick on this clutch. hope this helps you some
judging by the mixed reviews i thinnk im going to splurge on the triple and be covered instead of guessing...peace of mind i suppose.
back to the rebuilding topic though, i know you can completely rebuild these but there has to come a time when the cover/pressure plate is no longer useable..
