Help! "binding" noise
Old Dec 20, 2010 | 09:03 PM
B-rent's Avatar
I know I know this is kinda a wild goose chase to diagnose with out being able to physically see the car('03 gsr), but if you have any suggestions/ ideas please share. Within the last week I have noticed a binding noise coming from the front of the car when traveling at a constant speed hitting bumps in the road, and when down shifting from speed. The noise is not a hum or a grind, but more of a binding feeling that is on/ off. What are some first things to check? Any diagnosis tips?
Thanks EvoM
Old Dec 21, 2010 | 09:42 AM
barneyb's Avatar
Lubricant levels in engine, transmission and transfer case. Also, the power steering fluid and coolant.
Old Dec 21, 2010 | 10:22 AM
ODUB's Avatar
top mounts on your front suspension. bad bearings.
you're welcome
Old Dec 21, 2010 | 10:30 AM
4RETECH's Avatar
you're welcome
Exactly, upper strut mounts.
Old Dec 21, 2010 | 12:45 PM
B-rent's Avatar
After having the noise for a couple of days I went ahead and changed all fluids in the driveline, and I've still got the noise...
I have herd there is a link in the cv joint not associated with steering, but with suspention travel. Could this inner cv joint be the culprit?
Old Dec 21, 2010 | 01:04 PM
ODUB's Avatar
you're welcome
this
again
you're welcome
Old Dec 21, 2010 | 07:35 PM
B-rent's Avatar
Lol, I can take a hint or 3. upper stut mounts are next on the check list.
c08
Jan 2, 2017 11:45 AM
Firebat
11
Apr 19, 2016 01:43 AM
comced
Apr 11, 2016 08:53 AM
yoster4
Sep 19, 2010 08:02 PM
Dapper Dan
Nov 6, 2006 07:12 PM
