could i get some diagnosis help. (VIDEO)
Old Jan 13, 2011 | 07:31 PM
  #31
05VIII's Avatar
Originally Posted by b16a2delsol
there is actually a special tool from mitsu that will let you remove them without taking the cams off . Let me check out my manual and find it for you.
that would be sick..thanks
Old Jan 13, 2011 | 07:42 PM
  #32
b16a2delsol's Avatar
Not in my manual sorry. Good luck
Old Jan 13, 2011 | 07:59 PM
  #33
05VIII's Avatar
damn...ok well thats for trying to help. i might pop the valve cover off and inspect the lifters before i buy new ones
Old Jan 13, 2011 | 09:34 PM
  #34
silverIXMR's Avatar
check the pcv valve itself. the little ball inside can rattle like that. mine went one night and it is pretty loud. try squeezing it as tight as you can and see if it makes a difference. if not just try replacing it as it is only $17 from the dealer. good luck man.
Old Jan 13, 2011 | 09:38 PM
  #35
05VIII's Avatar
pretty sure its not the pcv. i replaced my valve cover a year ago so its not that old. its definitely inside the valve cover
Old Jan 13, 2011 | 10:00 PM
  #36
EvoJoeIX's Avatar
that sound is not a lifter
i would search for your problem elsewhere, your just wasting your time on all this lifter stuff
Old Jan 13, 2011 | 10:09 PM
  #37
05VIII's Avatar
well thats why im here asking for suggestions.
what do you think it is?
all iv gotten so far is lifters. maybe one got damaged with the new bigger cams since i didnt bleed them
Old Jan 13, 2011 | 10:27 PM
  #38
NOMIEZVR4's Avatar
Sounds very much like a spark arching. Possibly a injector being that loud and more noticeable around the rail area. Try swapping coils from cylinders and see if the noise travels.
Old Jan 13, 2011 | 10:54 PM
  #39
05VIII's Avatar
i dont think it would be easy to swap the coils unless i undo the wiring since its a cop.
im starting to think its a rocker rattling around like someone mentioned. maybe because a lifter got damaged and isnt holding oil very well after the bigger cam install.
doubt it could be spark arching. the boots on the cop are pretty long. the spark plug goes in there pretty deep. dont see how it could arch out
Old Jan 14, 2011 | 07:44 PM
  #40
05VIII's Avatar
update with picture on first page
Old Jan 14, 2011 | 08:01 PM
  #41
C6C6CH3vo's Avatar
That is your valve seal. It's supposed to be pressed in on the guid, but it's hard to tell from the pic. Is it higher up then the others? If it not sealed, you will be sucking small amounts of oil into combustion on intake stroke.
Did they replace the seals with the springs/retainers? If the didn't, and the seal (OEM) IS up near top of valve, then that might be bad because those seals do not come loose once they're on, and if they did it could be from something valve related. Just worst case scenerio here
Old Jan 14, 2011 | 09:02 PM
  #42
05VIII's Avatar
i think it was slightly higher. not 100% sure though, it was hard to tell.
would that cause the ticking sound i am getting?
and whats with the little spring?
Old Jan 14, 2011 | 09:06 PM
  #43
EvoJoeIX's Avatar
im not good at diagnosing cars online, but i do know thats not a lifter making that noise. i have ticking lifters, its not even close to the sound in your video. im just suggesting you check elsewhere
Old Jan 14, 2011 | 09:25 PM
  #44
brakeboost980's Avatar
Omg mine sometimes does.the same.thing but not.as loud
.what kind of spring kit.do u have,and injectors? ?mine does it right when the car is warming up and sometimes right after I get on it and lasts for 1 min less ..I been thinking and its either the oiling.using,injectors,Pcv,or Justin the nature of the cams and upgraded valve train.
Old Jan 14, 2011 | 09:31 PM
  #45
05VIII's Avatar
bc springs/retainers and fic 1250's with some gsc s2 cams
