Rings are bad what now??....:(
Old Dec 9, 2003 | 12:06 AM
timzcat's Avatar
Originally posted by Paytrick C.
To answer some questions.
The car is an Evo 6.5....not stock
The fuel system is stock........but is being helped tommorow....w/ walbro 255lph....paxton regulator...and afc
the white smoke is after warm up....but ends after the car has been run a bit........it does not smoke under acceleration and it is white not a bluish white
And I use castrol 20w50 racing oil...lol...if that helps
Thanks for all the replys....I love Evolutionm
One thing that stands out to me is the point at which it smokes.
Often a very minor coolant leak at the head gasket will exhibit these symptoms. Essentially you are getting the right mix of cylinder head temperature and block temperature to create the leak and then it goes a way when it's nice and hot and everything is expanded.
What is the spec for the oil in the 6.5? That seems a little heavy even though you are in Florida. Unnecessarily thick oil does nothing but rob power.
Old Dec 9, 2003 | 12:17 AM
potsuVIII's Avatar
You might want to check where the air is leaking when you do the leak down test. 7% isn't bad but it's not going to hurt to do further tests.
Try this: 1) open you radiator cap and look if it does bubble then its your head gasket or cracked block (check your oil and make sure there's no coolant mix); 2) open your oil cap and listen, if air is leaking there then it's your rings; 3) check your intake manifold by uninstalling the intake pipe and open the throttle body, if air is leaking there then the valve guides are worned out; 4) 2 ways, take out the turbo and listen to see if you have a broken exhaust valve or run the car on idle and put a paper at the tip of the exhaust and check if paper is trying to go in the exhaust like a vacuum. If it does then it's definitely a broken exhaust valve.
Reminder...these are the simplest things you can do before you move on and do any further work. It might save you some $$$. Just my .02 cents.
Old Dec 9, 2003 | 10:33 AM
Z1 Performance's Avatar
have you checked the coolant lines for the turbo?
Old Dec 9, 2003 | 10:39 AM
Dale_K's Avatar
Could it be normal? I see you're in Florida - did this happen during cold weather because every car will produce some condensation 'smoke' during warmup when it's cold out. Maybe you've never been in the right weather conditions before.
kylefowlie
Dec 21, 2015 11:54 AM
Fishd0
34
Apr 11, 2013 12:48 PM
ezzey
Dec 6, 2012 09:58 PM
08bluegts1
Lancer Aftermarket Forced Induction Tech
Jun 11, 2011 04:01 PM
badhabit90
56
Apr 5, 2008 02:54 PM
