New BW EFR Turbo Thread
Subscribe
Mar 12, 2013 | 07:25 AM
  #2431
Quote: Any 8374 serial number to check mine?
This was my original 8374, one of the early ones and as far as i know is racing and didnt fail.
Reply 0
Mar 12, 2013 | 12:03 PM
  #2432
Thank you for the picture
Finally I talked with the seller and he confirmed me that my 8374 has the newest turbine wheel
I understood that the turbo was in the shop from 2 years but I was wrong. He ordered the turbo 2 years ago but the turbo was in the shop from Nov 2012, then is the last turbine wheel version
Reply 0
Mar 13, 2013 | 05:07 AM
  #2433
so got my .92 a/r 7670 w/ the full race kit installed and initial tune done.
looking good so far even with stock injectors
Reply 0
Mar 13, 2013 | 09:39 AM
  #2434
Quote: so got my .92 a/r 7670 w/ the full race kit installed and initial tune done.
cant read your dyno plots... try making them darker.
pump gas?
about 395whp on 92 octane on 20psi. You've got another 50whp in that thing.
Reply 0
Mar 13, 2013 | 09:43 AM
  #2435
IWG and 93 octane?
Can you post a mods list
Reply 0
Mar 13, 2013 | 11:05 AM
  #2436
Quote: cant read your dyno plots... try making them darker.
pump gas?
will upload new ones and darken it up when i get home
sure can
mod list:
2011 evo x
stock head
stock bottom end
Invidia q300 cat back
Full-Race turbo Kit (manifold (small runner), intercooler, ic pipes, downpipe, lines + fittings)
EFR .92 a/r 7670 IWG
AMS Fuel Rail with -10an feed from surge tank, -8an return to surge tank
1 gallon surge tank setup with weldon 2025A fuel pump and weldon 14000 pump controller
here is a link to my build thread http://www.northeastawd.com/showthre...o-X-HPDE-Build
dyno was done using stock injectors on 93 pump because we were having issues getting the 2000s to idle leaner than 10.2 afr on pump. car made 343whp and 270wtq at 21 psi with the injectors at ~95% duty cycle and didn't really play with the mivec and ebcs is set to bleed off at 260 load. Once the injectors are taken care of, will really open it up.
Reply 0
Mar 13, 2013 | 12:40 PM
  #2437
Better graphs below.
Reply 0
Mar 14, 2013 | 04:49 PM
  #2438
better scans
Reply 0
Mar 17, 2013 | 02:10 AM
  #2439
Any requests? I'm putting my car on APRs Dynapack tomorrow for some final tuning on the 7670.
I'll be on pump e85. I plan on spending a good bit of time dialing in the mivec and the exhaust can gear at 20 psi before turning it up to 25, 30, 35, and if I can muster the courage 40psi.
The car looks amazing with the ccws and AD08s. Corner balance and alignment will be done tomorrow morning... Boost leak test... And then time to see what this turbo is made of. Then I'll decide if I really need to get the 8374.
Reply 0
Mar 17, 2013 | 10:06 AM
  #2440
Quote: Any requests? I'm putting my car on APRs Dynapack tomorrow for some final tuning on the 7670.
Yes, make a video.
Reply 0
Mar 17, 2013 | 11:24 AM
  #2441
honestly. the only request i would ask for is to push it. lets see everything it has. it is your engine though so you make the call. i and everyone one else should respect that.
best of luck and enjoy. cant wait to see
Reply 0
Mar 17, 2013 | 03:27 PM
  #2442
Blowing the spark out at 25-30... Need a spark tech!!!
Reply 0
Mar 18, 2013 | 08:20 AM
  #2443
Quote: Blowing the spark out at 25-30... Need a spark tech!!!
what symptoms do you get when it happens?
Reply 0
Mar 18, 2013 | 02:12 PM
  #2444
Try vw coil on plug. Cheap and very powerful with internal igniter. Very popular here and are used in lot of different engines. Available in different lengths.
Reply 0
Mar 18, 2013 | 05:35 PM
  #2445
Interesting, you guys run some big EFRs.
Reply 0
