CEL with HKS RS kit?
Old Feb 18, 2004 | 10:31 PM
JeffWels's Avatar
no guys the CEL was not related the HKS RS kit at all. The guy at autozone just didn't know what the code was. The code happened because water got into the o2 sensor circuitry and blew out the heating unit. Basically I blew out my o2 sensor.
the RS kit sounds badass, and I still recommend it for the money
Jeff
Old Feb 19, 2004 | 07:52 AM
JaReDbOy's Avatar
actually yes, there is an update.
lol.. it WAS in fact my clutch.
replaced it with the clutchmasters stage 3 clutch, everything is fine again.. aside from the stumbling idle.. but thats's actually been better with the cold.
the HKS RS kit is good i think.
just a little expensive.
Old Mar 17, 2004 | 11:52 PM
megatron's Avatar
ive just had my hks kit and hks back installed a week ago.. about two days later my cel went on.. the next day it went off.. then the next day it came back on and has been on since.. im guessing the stock ecu is reading too much air? is this something to get rid of it or is it natural with the setup i got going
Old Mar 17, 2004 | 11:54 PM
JeffWels's Avatar
pull the code at autozone or with a friends OBD2 reader. then just look it up online, you will know what the code is. It is most likely not due to the intake or cat back.
Old Mar 19, 2004 | 03:13 AM
megatron's Avatar
Originally posted by IS2000
I had a CEL related to my HKS RS kit before I got my Works reflash. The car was running too lean, and caused random cylinder misfire.
is there anyway to get the cel fixed or am i stuck with it until i get some sort of fuel management system
Old Mar 19, 2004 | 08:56 PM
bpclements's Avatar
Originally posted by Quickshift
Ya maybe AL didnt read the note or you got somone elses ecu. My car has never had a problem with my unit. Al does have specific maps for cars equiped with HKS rs unit due to the factor that it leans out the car at 4000 rpms.
So the Hks rs kit leans out the car from 4000 to redline? I am just curious because I have this kit on my car.
Old Mar 20, 2004 | 06:16 AM
Jadiem's Avatar
no CEL i have the RS intake and HKS turbo back...
Old Mar 20, 2004 | 01:20 PM
T_REX02's Avatar
Its your blowoff valves people......I have the hks intake kit too and when i put my type s on I get the same check engine light crap you guys get.....but when i put my recirc factory bov on then all is well and i've never got a CEL......peace out and support the troops
Old Mar 23, 2004 | 11:22 AM
bpclements's Avatar
I have a Turbo XS H34 bypass valve and I am recirculating it with no problems at all. Works great too and still is pretty loud. Sounds great.
