id 2200 injector problem...
Old Jan 13, 2011 | 04:01 PM
oofastlineoo69's Avatar
im currently trying to start my car that i built and the injectors arnt opening... bolth wires to the back of the injector plug are reading hot....the cam sensors are fine ... i just cant figure it out... i bought these injectors brand new...
thanks
Old Jan 13, 2011 | 04:05 PM
Silk's Avatar
Did you bypass the resistor pack?
Old Jan 13, 2011 | 05:26 PM
Yes.. I did stuff I'd driving me crazy right now...
Old Jan 13, 2011 | 06:06 PM
RSMike's Avatar
test them across a 12volt battery (click a wire on and off) and make sure they are actually opening to eliminate the injectors being the fault
Old Jan 13, 2011 | 09:33 PM
Thanks will try that tomarrow... There brand new I hope there not bad...
Old Jan 14, 2011 | 07:57 AM
The injectors work but I still can't get any injector pulse...
Old Jan 14, 2011 | 08:02 AM
Need help guys I'm trying to think if I missed any grounds or something....
Old Jan 14, 2011 | 09:49 AM
MasterNater's Avatar
Check to see if you're getting spark. If there's no spark and no fuel, it will most likely be related to your crank sensor.
Old Jan 14, 2011 | 10:03 AM
I have spark....
Old Jan 14, 2011 | 10:35 AM
When I crank the car the computer isn't reading any rpm...
Old Jan 14, 2011 | 10:41 AM
meld's Avatar
Hrm, if your car isn't reading any RPM, it doesn't seem like you have crank signal. I could be wrong but I think the RPM signal is from the crank angle sensor.
Old Jan 14, 2011 | 10:49 AM
I'm getting spark though idk I'm at a loss right now...
Old Jan 14, 2011 | 11:08 AM
CO_VR4's Avatar
simple question, but did you happen to unplug your crank sensor while installing the injectors? I know someone who did that once and it took a couple hours to figure it out
Old Jan 14, 2011 | 11:13 AM
Let recheck if it's that I love you no homo...
Old Jan 14, 2011 | 11:37 AM
Nope wasn't it....
