(Video) Backfire type nose (Pop Pop Pop) At WOT
Old Jan 24, 2011 | 02:42 PM
bnr34rb26dett's Avatar
Unhappy (Video) Backfire type nose (Pop Pop Pop) At WOT
so this has recently started happening to my car. at WOT at higher RPM my car starts to jerk and makes consecutive backfire type noise and lags a lot as it builds up boost.
It sounds like bah bah bah bah/ pop pop pop pop real quick
So far i have tried
resetting the ECU
checked MAF sensor connection
and it hasnt solved the problem
could it be the spark plug ? I have NGK BPR8ES spark plugs installed
Im also running E85 with a build Buschur motor on stock 9 turbo
Nothing on the car was changed before this started happening.
Old Jan 24, 2011 | 02:45 PM
Skylineracer's Avatar
From: Clifton New Jersey Lived: Daytona Beach, Florida Lived: Port Orange, Florida
Are the plugs Gapped correctly?
It sounds like bah bah bah bah or pop pop pop pop or however you want to put it real quick.
So far i have tried
resetting the ECU
Old Jan 24, 2011 | 02:47 PM
i bought the car used so im not sure at what length the plugs were gapped at..
but this just started happening. i never had problems before.
Old Jan 24, 2011 | 02:50 PM
mx4life85's Avatar
I would replace the plus and go from there. Especially with you having an evo 8 versus 9 the plugs should cost very little to replace.
It sounds like it's a misfire at high RPM under boost. My car had similar problems and I replaced the plugs, EVO 9 (IKH24) and the misfire went away. Now I have to replace them about every 6 months because the misfire will return after a while.
Old Jan 24, 2011 | 02:51 PM
should i replace it with the same NGK BPR8ES?
how far should the gap be for the spark plugs?
Old Jan 24, 2011 | 02:52 PM
AngryEvo8's Avatar
+1 the plugs probably need to be changed anyway. Start with them.
Old Jan 25, 2011 | 06:35 AM
bumping this
Old Jan 25, 2011 | 06:41 AM
achilles3000's Avatar
bumping this
How much power you making?
Old Jan 25, 2011 | 06:55 AM
Near 400 whp
Old Jan 25, 2011 | 07:04 AM
awdturbo8's Avatar
+1^^ swap the plugs and work your way from there.
Old Jan 25, 2011 | 07:05 AM
06EvoIXmr07's Avatar
Near 400 whp
99% sure its your plugs,if you havent retuned for pump and are still running the e85 tune its running rich and probably fouled them out.Mine did the same thing when i was tuning SD.I have some at my store right if you need them.
Old Jan 25, 2011 | 07:12 AM
New plugs of your choice but I would stick with the ngk mentioned above with a .22 gap.
Old Jan 25, 2011 | 07:31 AM
Pirana's Avatar
ok, just a shot...my car was doing the same thing at WOT, I checked plugs, etc...connections, etc...well d@mn I just saw a hose dangling from my F1 intake. WTF! Couldnt see it from the top and apparently just came all the way down to were I finally saw it from the bottom of the car! So I had a 1/4" air leak!!!!! Maybe your bov is leaking at WOT or maybe there is a hole in a silicone hose, or an air leak from a tube connection. Something else to check
Old Jan 25, 2011 | 08:26 AM
kuzma54's Avatar
Check ur plugs like everyone else stated...i run the same ngk plugs in my car with full bolt ons and a tune. runs realllllllly rich and it started popping and sputtering at WOT..changed the plugs (which were black as night) and it went back to running like a raped ape!
Old Jan 25, 2011 | 08:48 AM
blkmkIII's Avatar
Judging by the pictures you have of this car it seems pretty messed up, I think you should have someone who knows what they are doing look at it.
http://s719.photobucket.com/albums/w...124_142536.mp4
