Twin HKS BOVs and turbo in
Originally posted by Boost Solutions
If boosting high, one BOV cannot release enough air, that is why two.I had to either go with one HKS RAcing Type 2, or two HKS SSQVs. I like the sound of the ssqvs
George
George
Please advise
Originally posted by r6bruin
That's looks so freaking cool, and I bet it sounds just a cool as it looks. Btw, since you're running both BOV as VTA, do you encountered the imfamous stalling issue?
Please advise
Please advise
But I am installing the AEM tomorrow
All standalones work with MAP sensors, and they do not require for the BOVs to be vented to the intake. George
Originally posted by GokuSSj4
how much hp are you speting out of this set up ??
How much do you plan on boosting ?
also on what octane do you plan to run with no problems ?
The turbo will make more tough.
Pump gas will be 20 psi, race gas ( C16) will be 28 and 38 psi settings.
The last two settings will be done ONLY after the engine is built.
George
Originally posted by DrEvo
George I noticed you mentioned that you were going to run the AEM, what happened to the Autronic standalone
The Autronic has a better( i think) autotuning table, but I will be manually tuning either way:-)
george
Originally posted by Zeus
...that was a joke...
2nd week of January the engine is coming out for a FULL build
George
I am sure that I would be stalling if I had the stock ECU with a MAF sensor.
George
Please keep us posted!
OMG! Are the MAP sensors from the earlier Evos or is that a custom job? I got the HKS BOV and would definitely get some of those sensors to get rid of the stalling on my car....
Your better choice, especially if you are building the car, is to go with a standalone engine management. In that case, you just take out your stock ECU, and put in a different ECU ( standalone) that YOU can control with laptop. All SA ECUs work with MAP sensors, and they provide teh ultimate in tuning ability. They are way better than any S-AFC, e-manage, Xede, Dynoflash, etc.
Look into AEM, Autronic, and Power FC. All these are plug and play, with no to minimal (5 wires) wiring required.
Whne you have on eof these, you will set you redline, your fuel, timing, NOS control, traction control, starting, etc with a laptop. All of them come with base maps for a stock or lightly upgraded car.
I would look into the AEM or the Autronic.
If you need any help, or have any questions, feel free to call me at 770-904-2644.
George
George
Originally posted by value
George don't forget the HKS V Pro !!!
I knew I am forgetting something
The V Pro does not come with software, you cannot tune it yourself.
So the PnP standalones are
- AEM
- Autronic
- HKs V Pro
Non PnP
- Motec M800 ($$$$$$$$$$$$$$$$$$)
