Fp Red vs Fp Green
Old Jan 26, 2011 | 08:10 PM
sparky's Avatar
Originally Posted by tscompusa
you got it backwards....the red uses steel on steel thrust bearing like the black i believe and thats bad...the green uses steel on copper?
This sort of brain fart is commonplace on my part, ts. Sorry PSI if I got it mixed up though
Old Jan 26, 2011 | 08:15 PM
High_PSI's Avatar
the green uses steel on copper? i dont know what the other material is.
its all good tho if you run good oil..
i had the red on stock block, i loved it.. id get the red over green but the green is pretty good also though. cant go wrong on either.
I am getting the Red and stock block as well, why is it bad to use steel on steel and why does FP do this then if it is bad?
Old Jan 26, 2011 | 08:19 PM
tscompusa2's Avatar
it can tollerate overboosting the crap out of the turbo without burning up the thrust bearings. but if you dont use the correct oil you will burn them up anyways LOL.
Use either amsoil or brad penn or valvoline vr1 and youll be good to go. theres more on the list also the list is here: http://store.forcedperformance.net/m...otor%20Oil.pdf
Old Jan 26, 2011 | 08:21 PM
SWOLN's Avatar
My guess is they weren't aware of what was causing the problems. 1st was the oil line. 2nd it was oil with high ZDDP in it. This is all speculation on my part though. I read here that BB is on the way though. Again speculation.
Old Jan 26, 2011 | 08:31 PM
tscompusa2's Avatar
delete
Old Jan 26, 2011 | 08:38 PM
ct9asilver's Avatar
That soon huh? I was thinking at least by winter, did they say for the whole line up White-Black?
Old Jan 26, 2011 | 09:01 PM
High_PSI's Avatar
I wonder how much BB adds to the cost?
Old Jan 26, 2011 | 09:29 PM
sparky's Avatar
Originally Posted by ct9asilver
That soon huh? I was thinking at least by winter....
Next month is still winter.
Old Jan 26, 2011 | 09:30 PM
ct9asilver's Avatar
True lol!
Old Jan 27, 2011 | 09:39 AM
KRod223's Avatar
What I have done is the following bushcur exhaust down pipe injen intake Hbc boost controller and the following I purchased but havent put it in yet arp headstuds kelford 272 cams supertech valve springs retainers walbro fuel pump fic injectors 1250 cc what's the difference in hta an just a regular fp green
Old Jan 27, 2011 | 11:11 AM
High_PSI's Avatar
The Green is an OK upgrade but the power gains are short and sweet. The Red will walk all over it by at least 100WHP. Go for the RED.
Old Jan 27, 2011 | 12:07 PM
KRod223's Avatar
fp red vs fp green
Sounds like fp red is what I want ..... i can use that with the list of mods i got correct obivously a good tune as well
Old Aug 21, 2011 | 08:06 PM
Dmav1989's Avatar
Yea I'm also debating abt green or red but Im leaning towards the red! I need a hook up
Old Aug 21, 2011 | 10:57 PM
yeyeee evo's Avatar
pm spec ops they are running a sale on them
Old Aug 22, 2011 | 08:25 PM
94AWDcoupe's Avatar
Curt Brown maxed out both turbos on his car. The red made around 40whp more than the green on his car. 530ish on the green and 570ish on the red. although the red numbers were made in about 30 degrees higher temps there was also a cam change as well as some other tweaks... rounding up to 100whp seems a bit exaggerated.
He has also had all three colors on his car and just posted he cant wait to get green back on the car because it was the most fun street turbo he has ever used,
