Drain/fill plug washers?
I could be wrong, but I think
recomends changing them every time. I just did the tranny + diffs change myself, and the washers were pretty cheap. Be sure to use fliud with a proper friction modifier in the rear diff.
One other detail, I wouldn't suggest the Redline MT-90 for the tranny. I ordered some and found out it is GL-4 rated. The tranny wants a GL-5 fluid. I did use the Redline 75-90 in the diffs though (it does have a friction modifier) and it seems to be working great so far.
recomends changing them every time. I just did the tranny + diffs change myself, and the washers were pretty cheap. Be sure to use fliud with a proper friction modifier in the rear diff.One other detail, I wouldn't suggest the Redline MT-90 for the tranny. I ordered some and found out it is GL-4 rated. The tranny wants a GL-5 fluid. I did use the Redline 75-90 in the diffs though (it does have a friction modifier) and it seems to be working great so far.
