Help Clutch Problem
Old Dec 5, 2003 | 09:57 PM
T-boy's Avatar
Help Clutch Problem
On my second clutch(stock). The problem is when the clutch is released it doesn't stall out it just stays at idle and i was wondering can anyone here tell me if i should worry about tranny problems. Also yes the clutch is gone, i just got the car out of the body shop which it sat at for 4 1/2 months. And 2 days later my clutch blows. All the mods installed are the PWR radiator, Pruven intercooler and kit, and UR turboback. Should there would any lines or connections that i should look at b4 i go to dealer to install my cusco twin plate.
Old Dec 5, 2003 | 10:22 PM
MalibuJack's Avatar
Possibly a problem with the clutch fork or throwout bearing..
Old Dec 6, 2003 | 07:47 AM
BPAuto's Avatar
Silver Sponsor
So, the engine behaves as if you are not engaging or disengaging the clutch? It's probably what MalibuJack said.
__________________
"Let us help you build your JDM dream!"
www.bulletproofautomotive.com
The Real JDM - Interactive (blog)
Email: sales@bulletproofautomotive.com
Direct North American Dealers for Voltex, Mines, Varis, First Molding, HKS Kansai, Cusco, HKS, Advan, Volk, Ings+1, C-West, Work, and so much more...
Old Dec 7, 2003 | 02:36 PM
T-boy's Avatar
yeah it shifts into gear but doesn't stall out all it does is idle and not move. If it is the clutch what are the signs??
Old Dec 7, 2003 | 03:39 PM
T-boy's Avatar
forgot to ask wuts the clutch do sorry for the dumb question
Old Dec 7, 2003 | 05:17 PM
bpclements's Avatar
Can you shift into gear without even pushing the clutch in? If I am remebering right, the stock clutch assembly has stops on it to prevent the clutch from engaging when the clutch disc has worn down to much. It does this to prevent the disc from eating the flywheel up.
Old Dec 7, 2003 | 06:47 PM
Illrunya's Avatar
I suspect thats what happend with T-boys clutch situation since his clutch was slipping VERY badly right before this happend.
Old Dec 8, 2003 | 10:13 PM
T-boy's Avatar
sorry for the misunderstanding i meant to say wut does the clutch fork do again?? Friend of mine said if it was the clutch fork i couldn't get into gear but i can definitly get into gear it's just that it does nothing in gear just idle
Old Dec 8, 2003 | 11:38 PM
superz's Avatar
its sounds like the disc is worn so bad that its no longer making contact with the flywheel. This would explain why you dont have any problem engaging a gear without any grinding or bucking. I dont see a clutch fork being the culprit here.
Old Dec 10, 2003 | 08:49 PM
T-boy's Avatar
Thanks for the info, and superz are you the one wit the blue evo that works at ford scarsdale. Because i'm the other blue evo dat always chillin wit kenny.
Old Dec 10, 2003 | 10:41 PM
superz's Avatar
Yep, its me Gil. Give me a call about the clutch.
infam0usndn2nv
Feb 27, 2017 03:39 AM
cbarno042
Sep 1, 2016 05:47 AM
Rumblefish237
16
Sep 1, 2011 02:26 PM
machron1
30
Apr 30, 2007 11:11 AM
vassago
13
Mar 16, 2006 04:39 PM
