one WG on divided manifold ?
Old Feb 2, 2011 | 04:30 AM
bzyq2001's Avatar
hi guys, i'm new here;
i serched but not found straight answer - i'm doing custom divided manifold for gt35r wit t4 divided housing and i want to do only one WG with 2 separate pipes (1st form 1&4 cylinder and 2nd from 2&3) going straight into one WG (44 or 46mm) - will it work without boost creap ?
Old Feb 2, 2011 | 07:39 AM
spdracerut's Avatar
It should be fine as long as the fabricator does a good job on the wastegate flow path. Remember to keep a divider in there all the way up to the valve.
Old Feb 2, 2011 | 01:23 PM
bzyq2001's Avatar
i plan to
thx
Old Feb 2, 2011 | 01:34 PM
goodhart's Avatar
Not the greatest design/plan, but it has been done. I have a friend that has a single TiAL 38mm on a 42R on his DSM.
Old Feb 2, 2011 | 01:49 PM
bzyq2001's Avatar
so it's more us, that i expected
does he have any issues with that ?
Old Feb 2, 2011 | 02:47 PM
RSMike's Avatar
+1.
if you dont do a good job of that, it's all for nothing.
Old Feb 2, 2011 | 06:07 PM
goodhart's Avatar
He has a very *slight* boost creep, so don't expect to run any kind of low boost w/ only one EWG. He runs 37-38psi creeping to about 39.
Old Feb 2, 2011 | 06:40 PM
Jmelocik@Spec-Ops's Avatar
As stated earlier, it can be done but it must keep the gas flow separated all the way to the wastegate. Take a look at TedB's build thread. He may have even posted pics of it.
Josh
Old Feb 2, 2011 | 07:05 PM
n2oiroc's Avatar
why are you trying to avoid a second wastegate?
Old Feb 2, 2011 | 07:32 PM
RSMike's Avatar
weight, cost, complexity?
Old Feb 2, 2011 | 07:46 PM
sparky's Avatar
Dual gates would be better. Duals will give you better turbo spooup. As you can set the initial gate to open later since there will be a second gate to back it up.
Duh. For example .. Let's say that your target boost level is 27#: With two staged gates you could set the first gate really tight to 25# and the second gate to open at 27#. Otherwise if you only had a single gate then you would have to calibrate it looser and your turbo spoolup would suffer.
Of course, you probably have a different point of view. But that is OK. Needless to say, with dual gates you can run the 1st gate tighter since the 2nd gate backs it up. So, you will achieve faster turbo spoolup.
Old Feb 2, 2011 | 07:59 PM
EvoDan2004's Avatar
Duh. For example .. with two staged gates you could set the first gate really tight to 25# and the second gate to open at 27#. Otherwise if you only had a single gate then you would have to calibrate it looser and your turbo spoolup would suffer.
Of course, you probably have a different point of view. But that is OK. With dual gates you can run the 1st gate tighter since the 2nd gate backs it up. So, you will achieve faster turbo spoolup.
i dont get it. sorry. but if you have 2 gates ''2 runners per gate'' then how would making one gate stiffer then the other be a good thing?
both my W/G's have 22 or 24 ''i forget'' PSI springs in them. i would like a minimum of 28 but i do not think they make springs that stiff.
Old Feb 2, 2011 | 08:08 PM
sparky's Avatar
WG's are individually adjustable, are they not?
Old Feb 2, 2011 | 08:10 PM
sparky's Avatar
If you have dual gates then you can flow double the volume as a single gate, right? Duh.
Old Feb 2, 2011 | 08:11 PM
EvoDan2004's Avatar
i dont know. i thought only by spring pressure. o my. i feel a flame evodan coming on. haha
