hks bov how to install?
Old Feb 7, 2011 | 07:13 AM
nobodyphil's Avatar
i am running my hks "vta" and need to know how to install it. do you mount the hks bov to the intake pipe or the hose coming off the stock ic piping?
Old Feb 8, 2011 | 06:39 PM
nobodyphil's Avatar
anybody?
Old Feb 8, 2011 | 06:40 PM
milford's Avatar
pretty straight forward..just hook it up so its connected to the uicp
achilles3000's Avatar
You again.
Old Feb 8, 2011 | 06:46 PM
nobodyphil's Avatar
thats what i though but someone said hook it up like the stock one and mount it on the aftermarket intake pipe for "vta"
Old Feb 8, 2011 | 06:52 PM
You have to weld on a flange then put it on it..Then run a vac line to the intake manifold off the stock bov line and it's done.
Old Feb 8, 2011 | 06:53 PM
milford's Avatar
no you do not hook it up to the intake..it is hooked up like stock in the sense that its connected to the uicp, but since its vta when the pressure builds it vta since there is no other line running from the bov to the intake like in the stock configuration..you will have to plug the hole on the intake.....you should sell the bov and use a stock one. vta bov's are no good on evos unless you are converting to speed density
Old Feb 8, 2011 | 06:54 PM
That hks bov is junkaria.
Old Feb 8, 2011 | 06:59 PM
nobodyphil's Avatar
yea thats what i heard, but my stock crap plastic evo8 bov was leaking and not holding boost and i got a good deal on the hks. what bov do u recommend?
Old Feb 8, 2011 | 07:01 PM
milford's Avatar
get an evo 9 one. they are metal and you can put it in a vice and crush the top down a 1/4 inch which will compress the spring more thus making it hold more without leaking. I tested mine to 30psi with no leaks
Old Feb 8, 2011 | 07:04 PM
nobodyphil's Avatar
cool thanks, will the evo9 stock bov mount right in where the stock evo8 one goes? do i have to modify anything to get it to fit?
Old Feb 8, 2011 | 07:13 PM
milford's Avatar
direct swap!
Old Feb 8, 2011 | 07:16 PM
nobodyphil's Avatar
cool thanks is $80 shipped a good price? it only has around 4k miles on it, i have no idea what they go for
Old Feb 8, 2011 | 07:21 PM
milford's Avatar
yes that price is not bad. i made mistake on my original post.
Old Feb 8, 2011 | 07:25 PM
nobodyphil's Avatar
ok thanks for the info, ill look around for a better deal, do u know if u can hear the evo9 bov better than the evo8 bov? i have a aftermarket intake and can hear it a little.
