New clutch slipping in 1st and 2nd gear only?
Old Feb 8, 2011 | 04:13 PM
Lawdy's Avatar
so i took my car to a local tuner, and he notified me that my clutch was 1000% gone(stock) i bought and and installed a new exedy stg 2 4 pluck clutch and my car only to find out its doing the same thing, slipping in first and 2nd gear. i did the 5th gear test and it didnt slip. i also replaced the clutch slave and bled the clutch system, and still nothing.....
any ideas or help is greatly appreciated. also sorry if i posted this in the wrong place, as im still a noob
Old Feb 8, 2011 | 04:55 PM
03evo8gsr's Avatar
how many miles on new clutch? was it broken in properly?resurfaced flywheel?
Old Feb 8, 2011 | 06:26 PM
barneyb's Avatar
Something goofy here. A clutch always slips in the higher gears first.
Old Feb 8, 2011 | 06:34 PM
Lawdy's Avatar
Yes the flywheel was resurfaced, n I broke in the clutch for about 600 miles, less than 1000 on clutch
Old Feb 8, 2011 | 06:39 PM
achilles3000's Avatar
Sounds like you glazed the clutch very common on pucks not knowing how to drive them properly!!
Old Feb 8, 2011 | 06:46 PM
Lawdy's Avatar
New clutch time?
Old Feb 8, 2011 | 09:57 PM
still*boostn's Avatar
New clutch time?
No, Drive it around for another 500 miles around town. Also go ahead and bleed/re-bleed the clutch line for *****-n-giggles.
Also did you adjust the clutch pedal after the install?
Old Feb 9, 2011 | 05:31 AM
Lawdy's Avatar
Yes I did adjust the pedal, I have no thread coming out of the nut on the clutch pedal. So clutch engages pretty high up.
Old Jun 25, 2013 | 12:19 AM
Dbz00's Avatar
I have the same problem. My 03 evo 8 just got a new act 6 puck and my car is slipping like crazy. Need help. It only got like 10 mile on the disk.
Old Jun 25, 2013 | 01:08 AM
17pstockcar's Avatar
Dont be gentle on it. U cant let it slip. Im not saying dump it but get off the pedal fast
Old Jun 25, 2013 | 06:48 AM
Dbz00's Avatar
So u say that it normal for my clutch to slip like that. When will it start to not slip no more or how u make it stop slipping.
Old Jun 25, 2013 | 11:10 AM
egis's Avatar
i had the same problem after ACT installed i kept driving for another two weeks(around 600 miles) and everything went to normal.your situation might be different but i hope everything gonna be alright.gl
Old Jun 26, 2013 | 12:03 AM
If your meaning my comments im not saying its normal.
Its not good for the clutch to be slipping.
When you drive you cant be gentle or slow on the clutch.
U want the clutch to bite into the pressure plate and grab not slip against it ( this will cause glazing.
Its hard to explain via txt
Old Jun 26, 2013 | 12:57 AM
deylag's Avatar
If you think that the clutch is installed properly and the flywheel was also replaced then the problem must lie in another part of your drive-train. I would guess the transfer-case.
Old Jul 11, 2013 | 09:43 PM
Dbz00's Avatar
When i jack my evo up on all 4 jack only my two back wheel are spinning and my two front are doing nothing. What do that mean.
