Bov Question??
Old Feb 8, 2011 | 08:05 PM
achilles3000's Avatar
Bov Question??
I have a tial 50 mm bov on my 9 and hear it loud at part and half throttle but not full throttle is this normal??.I have it hooked up to a vac valve is it causing some type of interference with it blow off rather then have it straight of the manifold or it doesn't matter?The mac valve is a 3 port.
PIC UPLOADED FOR BETTER HELP!
Old Feb 8, 2011 | 10:24 PM
Old Feb 9, 2011 | 11:47 AM
raasfaas's Avatar
It could very well be because of the 3-port. I believe it's the same effect as having an mbc t'd in the line (which is basically acting as a controlled vacuum leak)
The best way to run the bov is a straight line from the manifold with nothing interrupting it.
Also, you should be hooking up that 3-port to a boost source like your compressor cover...just my $.02
Old Feb 10, 2011 | 08:23 AM
?? anyone else on this??bump!
Old Feb 10, 2011 | 07:09 PM
I just saw a tumble weed..Lol anyone??Thanks.
Old Feb 10, 2011 | 07:32 PM
Boost Demon's Avatar
Veteran: Air Force
The folks at Tial recommend that you run a dedicated 1/4" line from the intake manifold (boost source) directly to the BOV w/ nothing tee'd into it.
Old Feb 10, 2011 | 07:41 PM
I guess this would be a t?? The top left port goes back to the i.m and the to right vac line is to the wastgate .??ANy thoughts on this.
Old Feb 11, 2011 | 05:26 PM
Veteran: Air Force
I believe they both need a boost source, definitely get the BOV one from the intake manifold. Check the How-To link below, maybe someone else can chime in though good luck.
https://www.evolutionm.net/forums/ec...-solenoid.html
