Head gasket options for 2.4L Mivec
Old Feb 14, 2011 | 07:58 AM
ezz-e's Avatar
I'm currently running in to problems in my build. I am building a 2.4l Mivec motor and i install a OEM mivec 9 head gasket. while inspection it i noticed that the gaskets edge protrudes into the cylinder. Is there a specific head gasket i must use or do i have to cut out the extra gasket that is sticking out into the cylinder? the bore is 87mm.
Old Feb 14, 2011 | 08:01 AM
NickieBlaine's Avatar
You will have to go with the 4g64 gasket, or get one like ams makes.
Old Feb 14, 2011 | 08:06 AM
VGergo's Avatar
i will go with this as suggested in the other topic : link
Old Feb 14, 2011 | 08:41 AM
miragevo's Avatar
Veteran: Navy
I would go with the .040 gasket in the link below as opposed to the .051
http://www.raceeng.com/p-8332-mls-ga...7mm040-ea.aspx
Old Feb 14, 2011 | 10:41 AM
94AWDcoupe's Avatar
keep in mind cometic gaskets suck.
Old Feb 14, 2011 | 04:38 PM
JohnBradley's Avatar
The cometic HD sucks. The Cometic we run holds up to 48psi and 1050whp. Mine has had no issues at 750whp. The AMS modified stock one fails at 39psi, the PE seems to fail over time or rev limit induced but it burns the fire ring out.
Its not the gasket so much as the prep. If the block and head prep arent right it doesnt matter what gasket it is in it, it will fail.
Aaron
Old Feb 14, 2011 | 04:52 PM
David Buschur's Avatar
Cometic sucks, I'll agree with that for sure. I've never seen an AMS gasket blow unless the tune was off enough to torch the head too.
Old Feb 14, 2011 | 05:52 PM
miragevo's Avatar
Veteran: Navy
Aaron
Is the Cometic you run the same one I posted the link in, in post#4?
Old Feb 14, 2011 | 05:53 PM
Well thats why I said some of the Cometic sucks. Look close at Cosworth EJ25 gaskets...you might be surprised who actually makes it.
Aaron
miragevo's Avatar
Veteran: Navy
What is your solution to this gasket dilema?
Old Feb 14, 2011 | 05:54 PM
nope...PM sent though.
miragevo's Avatar
Veteran: Navy
What is your solution for a gasket with an 87mm bore?
Old Feb 14, 2011 | 05:55 PM
AWD Motorsports's Avatar
+1..
Ran the AMS in the Bastard down to 9.3's and lets just say it was DEFINITELY over 39psi..
Mike
Old Feb 14, 2011 | 05:56 PM
SIMPLE.. OEM bored to 87mm.. It works..
Mike
Old Feb 14, 2011 | 05:57 PM
I have heard of 3 separate ones fail at 39psi. I know well enough that tune is very important, rev limit abuse, timing, AFR, etc. They modify a stock fire ring though and the smaller that gets the worse off it is over all.
The 1G runs 11.3:1 compression and 48psi on Q. Cometic has held up to every bit of abuse we throw at it until a nitrous fuel solenoid fails in duty.
