Ams?
Old Feb 14, 2011 | 07:08 PM
LancerBri1120's Avatar
Ams?
Should go for the 900xTurbo kit when I get my evo & want to upgrade the turbo system or maybe something smaller than that?
http://www.amsperformance.com/cart/A...Turbo-Kit.html
Old Feb 14, 2011 | 07:18 PM
recompile's Avatar
It's a $4400 kit that requires a lot of supporting mods beyond whats included.
Why don't you start with the basic bolt-ons and maybe a stock-framed turbo like the HTA Green or FP Red.
It's rare that you see someone turn a stock(ish) Evo into a 600whp car overnight... and there's a lot of good reasons... (besides the $8000+ you'd have to spend on turbo kit, intercooler & piping, fuel pump & injectors, clutch, exhaust, cams... and probably a built motor.)
It's also a learning experience to mod slowly and see how each mod changes the car. If you up and change everything at once, you'll have a lot less respect for each mod's benefit and true need... and if a problem should arise, it could be any one of the 50 parts you just installed.
Old Feb 14, 2011 | 07:21 PM
limp_noodle's Avatar
^ what he said.
I have an AMS 35r kit sitting in my garage. Its not going on my car anytime soon. I'm gathering up all of the supporting mods for my build first before I even think about slapping it on.
Old Feb 14, 2011 | 07:22 PM
mc14's Avatar
Really...
Old Feb 14, 2011 | 07:26 PM
I definitely understand where you're coming from and will definitely follow. I've been around Evos for a bit. I'm somewhat new to the forum & I was just putting this out there for a feeler to see the road I really wanted to take on the modding journey. Thanks though. I appreciate the help
Old Feb 14, 2011 | 07:47 PM
way2qik's Avatar
Which Precision turbo do you get with their "900x" kit? Is is a 6765?
Old Feb 14, 2011 | 10:33 PM
skyway69's Avatar
^^ it 6265. for their 950r is 6765..
TS; best is u collect all the parts 1st, buy in stages such as what u need for yr short block then long block then fuel systems & last be the turbo & headed....not to forget ems too...
Old Feb 14, 2011 | 11:20 PM
tscompusa2's Avatar
EMS is a free mod to us thanks to the coders, decompilers, and assemblers on this forum
Old Feb 15, 2011 | 06:42 AM
Xenogenic's Avatar
I'll answer your question. Yes the precision 6262 works great on our cars
Old Feb 15, 2011 | 08:14 AM
ETS Michael's Avatar
Old Feb 15, 2011 | 01:49 PM
Where are you located in PA?
Old Feb 15, 2011 | 07:31 PM
KarmaSRT's Avatar
Do it man I started buying cams injectors motor and trans mounts head studs clutch lines bushing exhaust piping a clutch blah blah blah and then I was like why don't I buy the ams intake manifold and a 850r kit and here I am today making 561hp and 463t on stock bottom end do it I dare you
Old Feb 15, 2011 | 07:49 PM
casper980's Avatar
The AMS 900x (PTE6265) is what I want my next turbo to be...I am just waiting for the current one to punch out. Like others said above, lots of supporting mods needed. Step 1, buy Evo, Step 2 learn how to drive it, Step 3 read, read and re-read every thread on this forum, step 4 buy the right supporting mods the first time with end goals in mind. Step 5 Make your own call on which turbo you want to run based off your power goal and what you have learned along the way.
Old Feb 15, 2011 | 07:50 PM
casper980's Avatar
The AMS 900x kit is not a 6262 its a 6265
Old Feb 15, 2011 | 07:55 PM
Dynotech Tuning's Avatar
There is no problem if someone wants to go right to step 10! Just do it all right the first time. Saves you a ton of money in the long run. Just make sure you bring it to a great shop to tune it if you don't/can't tune yourself. Your huge purchase will suck big time if its not tuned properly, and or you will blow the **** up!
-Brian
