New QM clutch shims installation
Old Apr 13, 2012 | 03:54 AM
  #31
psphinx81's Avatar
you dont have to shim..
Old Apr 14, 2012 | 12:47 AM
  #32
EvoDan2004's Avatar
thanks.
clutch is in with no shims. i trqed the flywheel bolts to 100ftlbs and the pressure plate to 20ftlbs. trans is back in as well. this is my first trans removal and clutch install so i hope i did it all correctly.
Old Apr 16, 2012 | 09:59 PM
  #33
EvoDan2004's Avatar
soooooooooooooooooooooo um
while i was cleaning off my table i noticed a supper small black O-ring in the same bag the shim kit came in. the car is totally back together. was i supposed to use that o ring for something on the clutch?????? or is it an extra for something. im a wreck right now thinking about this
Old Apr 17, 2012 | 08:24 AM
  #34
R/TErnie's Avatar
Its an o-ring for the additional fitting they give you. It was installed on the fitting in my bag. No worries.
Old Apr 17, 2012 | 08:27 AM
  #35
R/TErnie's Avatar
Originally Posted by 03whitegsr
The pedal stop is suggested to prevent over extension and possible damage. I think I saw one post on this board where somebody damaged a QM when they didn't use a pedal stop, but maybe they had shimmed it?
The reason I would use a pedal stop though is the engagement point. The clutch only takes about 3/4" of pedal travel to fully engage. This means you have about 3" of "dead" travel from the floor and it makes it pretty hard to tell when the clutch is going to grab when leaving a stop. Put the pedal stop on there and cut that dead space down to about an inch and it makes it A LOT easier to drive on the street.
Gotta run the clutch stop so you can put a switch on it and run gear cut.
Old Apr 17, 2012 | 11:13 AM
  #36
EvoDan2004's Avatar
thank you
Old Apr 17, 2012 | 02:51 PM
  #37
WickedIXMR's Avatar
I guess I'm gonna run no shims in mine too. Glad I came accross this thread lol.
Old Apr 17, 2012 | 03:40 PM
  #38
droppinbottom's Avatar
I paid to have my Qm 8 leg installed rather than doing it myself and the shop said they had to shim mine to the tune of a extra $75 fee for the extra time it took to shim it.
Old Apr 17, 2012 | 08:30 PM
  #39
4g63evoeight's Avatar
I'm interested in the pedal stop.. Is there a link to one that people have used or something? It was either the qm 8 leg or exedy triple and I didn't want to have nitmares about the clip popping off plus the qm is lighter and doesn't have the problem that the exedy has with the disks wearing out the hub thing
Old Apr 17, 2012 | 08:35 PM
  #40
n2oiroc's Avatar
https://www.evolutionm.net/forums/ev...edal-stop.html
Old Apr 17, 2012 | 09:17 PM
  #41
Perfect. Thanks!!
Old Apr 17, 2012 | 11:29 PM
  #42
R/TErnie's Avatar
I spoke to QM today. You should measure your offset as it explains in the instructions. If you're close to the recommended .130" offset...leave it. If you're way off you will need to shim. They were saying that 1 car out of 50 needs shimmed.
so it's not that it shouldn't be done, it's that it's highly unlikely that its necessary.
Old Apr 18, 2012 | 12:00 AM
  #43
ranz's Avatar
since i started the thread i kept asking here and there, and then i installed mine without any shims bec i was told evos dont need that. and its working with no problem.
however, as R/TErnie stated that the right thing to do is to measure it although u might not need it.
Old Apr 18, 2012 | 04:04 AM
  #44
Steven's Avatar
Be sure to take the measurements. Mine was just at or below the minimum clearance without shims. My release bearing started touching my pressure plate fingers all the time. I think I caught it before too much damage was done. The clutch is on the way to QM for inspection.
Old Jun 25, 2012 | 04:56 PM
  #45
Lexus01IS's Avatar
Does anyone have install pics?
I am ready to install mine in few weeks.
