65mm tb on stock manifold?
Old Feb 23, 2011 | 07:13 PM
killerpenguin21's Avatar
does it make any sense? cause any problems?
basically id much prefer to buy a tb and keep my stock one aside than try and trust myself replacing the tb seals on the factory one of my dd (im truly scared of messing with the tps lol)
in my mind i feel like it should pretty much just act like stock...
Old Feb 23, 2011 | 07:15 PM
Jedi_Gill's Avatar
FCOTM Winner
Honestly, I don't know what else you have done to the car, but to change the TB to add more power I feel is pointless. I would only change it the stock seals start leaking which they are known to do. And for your reference I have a Boomba 65mm TB on a Stock manifold and made awesome power. But like I said I have a FP black to compliment the needed airflow.
Old Feb 24, 2011 | 10:50 AM
Aby@MIL.SPEC's Avatar
if you put a 65mm tb on the oem mani, you must enlarge the inlet opening of the int mani, otherwise you will only realize a response gain.
GL
Old Feb 24, 2011 | 11:04 AM
mdsevo06's Avatar
^ and you can do this with the mani still mounted.
Old Feb 24, 2011 | 01:19 PM
GL
please read what i wrote.
im not doing it for the performance. i was doing it more out of the fact that i almost dont trust myself to play with the tps to replace shaft seals, so i figured why not just get a mil.spec tb already done up.
i just want to make sure there will be no NEGATIVE effects. I am not worried about maximizing it at this point.
Old Feb 24, 2011 | 10:09 PM
i can offer you a rebuilt unit that is built up in oem form if your interested, which will be cheaper than going the 65mm route
Old Feb 25, 2011 | 03:24 AM
If you could om me a price on that, that would be great. Otherwise I'll pm you when I get out of work.
Darewood
150
Dec 10, 2016 03:16 AM
awdordie
12
Apr 21, 2014 04:33 AM
jwick76
Sep 10, 2012 12:59 PM
evo1008
Jan 31, 2012 09:55 PM
jwick76
Lancer Engine Management / Tuning Forums
52
Nov 20, 2011 11:35 PM
