Infamous p0300 fix?
Old Feb 25, 2011 | 08:40 PM
erald01's Avatar
P0300 is nothing more than the knock sensor being veeeery sensitve on 03 evos due to trans vibrations. I have goten before plenty of time and the funny thing is that i do not notice a misfire or loss in power. Some people get a reflash at the dealership for $150 (i think) and some just lower the sensitivity of the sensor through ecuflash when they tune the car.
Old Feb 25, 2011 | 08:54 PM
mifesto's Avatar
do you have transmission vibrations in 5th gear?
Old Feb 25, 2011 | 09:18 PM
barneyb's Avatar
It is my understanding that it is not the knock sensor but the crank sensor that is involved. When the triggering of the crank sensor has certain irregularities the p0300 code it set.
Old Mar 5, 2011 | 02:39 PM
adnmoh1's Avatar
its neither sensors its either rom upgrade need new id or for my car its a tsb needing to change 5th gear input shaft seal a $1.73 part of which mitsu is quoting me as today mar 5 2011 $1721.34 plus tax. feel like i want to eat a bullet.
Old Mar 5, 2011 | 02:45 PM
bigben's Avatar
F that. I'd just send the tranny off and get it rebuilt/upgraded for right around $1k or a little less. Also, updating the ecu rom (as stated earlier) and getting a tune always helps. My 03 used to always do that. Now it's been 4wstuned: quoth the raven, nevermore.
Old Mar 5, 2011 | 04:22 PM
da_yo's Avatar
I too had that code but it finally spit the misfire code for cylinder 2 and it ended up being a bad injector.
Old Mar 5, 2011 | 06:12 PM
killercd4G63's Avatar
Veteran: Army
Originally Posted by adam_79_2005
random missfire, could be the spark plugs, the ignition coils, could even be one of the injectors, one of my injectors went bad so I was missfiring aswell, hilarious story, my car sounded like a subaru LOL
Had the same problem. had all of these problems at once
1. Bad spark plugs (cause by the next)
2. Broken Coil Boot (metal piece)
3. Bad/Clogged Injectors
All of the following plus RANDOMLY my CEL light would come on
had a tuner shop fix all of it
roni4g63
Nov 16, 2015 05:10 AM
KJS
Jan 4, 2013 06:49 PM
rishi_j
Apr 22, 2011 04:03 PM
project_skyline
13
Oct 1, 2009 09:29 PM
soontobe
Apr 13, 2009 09:55 AM
