opinions on 6 spd when did yours break
i have no failures. 45k of weekend drag. 10-15 runs a night 6k dump launches. probably 50 pulls at 160-170mph. and three 24hour straight through trips from el paso to chicago. i've ran the exedy twin carbon and two stock clutches i had 316hp 326tq for a couple years. then turned up to the boost just under 400hp. i also have one of the only 6sp short throws if it matters. i've had 2 oil changes... no shavings no grinding no whining
Is that a very conservative tune? I would be expecting numbers more in the 315whp and tq range.. I know with a 9 turbo you'd most likely be there, but those numbers just seem low to me. I would hope to make around 275whp on all the mods you have listed minus the UICP, FMIC & possibly the 02 housing.
Every dyno is different, but the point of this thread is to get a rough estimate at what power levels people run their 6 speed at and does this lead to failure.
PM me if you want to discuss what power you may obtain during your upcoming tune!
STM's 'Ricer' makes 783awhp on the same dyno and runs a 9.2sec 1/4.
http://www.streettunedmotorsports.com/gallery.htm
No breaky yet.
67K miles. ~180 passes at the drag strip and 35 Autox's. I've also been cruising around on the autobahn for the past 4 months at an average speed of 100-105mph (several hours at a time). I've probably racked up a good 1,500 miles at that speed so far. ~300-315 WHP/WTQ on an MD.
No breaky yet.
Mikey
