Cannot find 6th!!!
Old Mar 1, 2011 | 12:44 AM
skimskim3074's Avatar
Originally Posted by xRoguex
sounds like someone took a joy ride in your car and beat it all up.
the more miles you put on it between when they had it, and when you get it back, strengthens their defense of "We didnt do it"
sounds bad experience.
Old Mar 1, 2011 | 06:40 AM
goodhart's Avatar
Have you contacted them about this yet?
Old Mar 1, 2011 | 09:01 AM
svt_lightning01's Avatar
yes i contacted them within minutes of leaving the shop and have spoken with them twice since then. They think that it is something they have ran that is kinking the linkage or binding the pole from going into sixth. If i dont have it figured out by friday im taking it to them. Im meeting a guy tomorrow thats pretty sharp and should be able to diagnose the problem for me so they can't bs me on it. It honestly doesn't feel like a fork because everything else is smooth including reverse. If you watch under the hood while someone shifts inside, the hub tries to engage sixth but doesn't quite lift up high enough on its own if you give it a little help in the upward direction it will slide itself into sixth. Hopefully it just needs adjustment.
Old Mar 2, 2011 | 08:43 PM
okay guys i fooled with the car tonight im still taking it back to the shop that did the work on friday. I can put the car into 6th from under the hood but still not from the gear pole. I fooled with the adjustment in the cab connecting to the pole and still no 6th. I still feel like something is just bent and nothing inside the transmission is jammed but i could be wrong. 1-5 and reverse are smooth as a babies bottom and under the hood you can see it try to engage 6th but the hub doesn't quite raise up high enough
Old Mar 2, 2011 | 08:55 PM
Aaron20's Avatar
Is it a 5 speed?
Old Mar 2, 2011 | 09:17 PM
NO? haha ive had i in 6th before shop work
Old Apr 28, 2011 | 06:56 PM
okay guys been awhile since i last updated. Turns out the 5/6 hub slider was burred. Got that replaced and she runs like a dream!!!!!
Old Apr 28, 2011 | 07:21 PM
3gEclipseTurbo's Avatar
Originally Posted by Aaron20
Is it a 5 speed?
I was gonna say the same thing
Old Apr 28, 2011 | 11:13 PM
oly kenji's Avatar
Originally Posted by SRTRaceR04
It's right below 5th!!
haven't lold at a comment in a whilel!
agtpony
Mitsubishi TC-SST Discussion
May 22, 2014 01:18 PM
SadMan
10
Jun 3, 2012 03:36 PM
svt_lightning01
Apr 18, 2011 12:26 AM
Sixth_Vang
34
Nov 6, 2009 12:05 AM
Sixth_Vang
Oct 19, 2009 06:08 PM
