Did it blow up??
Old Mar 2, 2011 | 11:57 AM
  #31
Kapoosh1's Avatar
lol, Ya I can't wait. Hope this doesn't end up being to big of a setback.
Old Mar 2, 2011 | 03:57 PM
  #32
Kapoosh1's Avatar
FINALLY had time to play with it.
Pulling spark plugs 1 and 4 had no change on the car. I ended up putting everything back together and just unplugging the coilpack on the right (which is cyl 1 and 4) and it made no difference in how the car ran. I then plugged that coil back and unplugged the other coil and the car wouldn't even start....
My conclusion is a bad coil, but before I go spend the money anyone want to tell me i'm wrong? lol.
Old Mar 2, 2011 | 04:01 PM
  #33
tscompusa2's Avatar
yep.. it definitely is probably running on 3 cylinders then. id say 3 because it would sound like a dirt bike on 2 cylinders and it doesnt sound that off in the video.
Old Mar 2, 2011 | 04:03 PM
  #34
Kapoosh1's Avatar
Just for the record it sounds quite a bit worse now than in the video. No idea why it got worse, but it won't hold idle for more than 15-20 seconds without dying if I don't give it gas.
Old Mar 2, 2011 | 04:39 PM
  #35
Aaron20's Avatar
it got worse because there is a build up of fuel in the cylinders on the plugs. If I was you I would pull the valve cover and inspect the rocker arms before you go out and buy a new set of coils! If im wrong then you are not out the $$$ but if I'm right then you will have saved the $$$ you'll be spending on the coils.
Old Mar 2, 2011 | 04:49 PM
  #36
Kapoosh1's Avatar
hm, and on a cold start it still sounds fine for a minute or so, then it drops atleast a cylinder. I need to find someone local with an evo and swap the coils. I'm pretty sure the cars running on 2 cylinders at this point.
To cold to pull the valve cover tonight, probably won't have time till the weekend.
Old Mar 2, 2011 | 06:29 PM
  #37
Kapoosh1's Avatar
Swapped the 2 coils and the problem followed the coil, so I think I can say with confidence now that I've discovered the problem.
Old Mar 2, 2011 | 06:51 PM
  #38
Aaron20's Avatar
^thats a good way to do it to! lol
Old Mar 2, 2011 | 07:03 PM
  #39
Kapoosh1's Avatar
Ya, would've saved me a lot of time, lol. Sometimes common sense just seems to go out the window.
Old Mar 2, 2011 | 07:07 PM
  #40
Aaron20's Avatar
^lol yep!
Old Mar 3, 2011 | 07:26 PM
  #41
b16_rex's Avatar
hey man I no you got it strait but also another little thing to keep an eye on and my car did the same thing is my injector plug lifted up on one and caused the same prob. So keep an eye on them just alittle added advice
Old Mar 3, 2011 | 07:32 PM
  #42
BoostWhore's Avatar
was going to say bad coil or something with a valve. Simple compression test and swapping out the coil would work also.
Old Mar 3, 2011 | 07:36 PM
  #43
tscompusa2's Avatar
I really advice you buy the U clips.. i know of a guy whos engine blew from lifting an injector WOT.
Old Mar 4, 2011 | 11:32 AM
  #44
Kapoosh1's Avatar
I'll have to see if I have u-clips on the injectors. Sucks waiting for a new coil. 60 degrees here, just want to drive my car!
Old Mar 4, 2011 | 06:18 PM
  #45
dastallion951's Avatar
well if your gonna spend the money and buy a new ignition coil, spend the money and either buy new wires and new coil boots with it, or if u plan to stay stock ecu go buy non cdi sparktech coil on plug, no problems on mine had it on over a year... 500 for an ignition that can spark as much as that 6262 can put out means no spark blow out, some ppl on here are givin good information, some just need to stfu....haha
