Catch Can(Is this worth the money)
So im working on getting the rest of my parts for my 2.4 build. I am sure I need a catch can but there are so many to choose from. I found this one on ebay that looks decent.
And yes I did search
http://cgi.ebay.com/ebaymotors/MITSU...Q5fAccessories
That thing looks ballin for only $50!
But any catch can should work also, whether it is a $5 one or $500, they will all work equally. I never understood the guys that just had to have some fancy pants catch can, waste of money IMHO.
Just make your own catch can. All the big company ones are big overpriced crome things when really you can make your own out of a few air tool fittings and a clear container so you can check the level. The catch can dosnt need to be much bigger than a pill bottle, becuase youll probible empty the can every time you change the oil so having a catch can the size of a forty of OE is just a waste.
It's easy to make a can that does nothing. Here's a link to a proven catch can. He's a member on this forum. http://www.saikoumichi.com/
It's easy to make can that does nothing. Heres alink to a proven catch can. He's amember on this forum. http://www.saikoumichi.com/
read this lots of info in here.. https://www.evolutionm.net/forums/ev...re-issues.html
don't waste your money, just run a tube to the bottom and drain it on the ground, there won't be a lot of oil/moisture to be seen on the road, I've been running this setup forever. I used to have a catch can by the pvc valve and it fills so fast
thats because it wasnt doing its job. i did about 50-70 pulls at 600whp on my 2.3 and maybe a teaspoon of water/fuel mix came out of my catch can.
please do not do this
