What Vendors use Metal O2 Dump Gaskets?
Old Mar 26, 2011 | 06:51 PM
bboypuertoroc's Avatar
Veteran: Army
For those of you with O2 dumps on your stock/stock-frame turbos... did the vendor you bought your dump from supply a metal gasket that separated the exhaust side from the wastegate side (like the stock gasket, but connected in the center)? The one I was supplied with (soft type) burned through the part that separates the two sides and now exhaust is leaking from the dump tube.
If anyone's got a hook-up on this please let me know. Thanks.
Old Mar 26, 2011 | 07:06 PM
BluEVOIX's Avatar
I dont run a dump. I have the MAPerformance 3" o2 housing with quick disconnect from downpipe. However they sell a o2 dump 20g stainless steel gasket for your application type.
Here you go.
http://www.maperformance.com/maperfo...og-ss-evo.html
Old Mar 26, 2011 | 08:17 PM
Veteran: Army
You're my hero. Thanks.
Old Apr 24, 2011 | 10:03 PM
s.e.a.n.'s Avatar
I need this
Old Apr 25, 2011 | 07:29 AM
asubennett's Avatar
Ha. That darn gasket. I installed MAP's O2 Elim downpipe and like a dummy reused the stock metal gasket.
Started the car up and oops, exhaust right out the dump tube - path of least resistance I suppose. Just recieved the MAP gasket in the mail. Seems like a nice solid quality metal piece. No burn through possible on this guy.
jk_evo8
May 7, 2016 08:44 PM
Ude Lose
32
Sep 17, 2015 11:50 AM
clubchico15
Aug 2, 2012 04:50 PM
BoostWhore
15
May 5, 2010 03:44 PM
EvoDom
23
Feb 4, 2009 08:55 PM
