Need advice on o2 dump leak. Bad flapper?
I have a stock Evo turbo and I put a o3 dump out thru hood. Put the divorced gasket on and at idle car is leaking thru dump. Tried everything from new gasket and wga. I think the flapper is the problem. Maybe not seated right. Any way to fix a flapper problem without replacing turbo or housing. Any advice please as the car is apart at moment.
Adjusted waste gate actuator to fullest. Flapper seems to be not able to stay shut. Air pressure is able to push it open a slight bit. Have it off. Some build up but the flapper. Maybe I can clean up the build up
MrEvo420
Aug 29, 2015 03:46 PM
pupo
11
Oct 25, 2012 04:35 PM
blackevolution8
Jan 26, 2010 01:10 PM
Blue Evo 8
13
Mar 8, 2006 03:55 PM
