Should I have more boost than 12 psi
Old Mar 27, 2011 | 08:09 AM
Sanny632's Avatar
Should I be creating more boost than 12psi I have a few things done they are listed in my signature. But I am at a spike of 12 and a steady 10 psi. Sorry super noob here
Old Mar 27, 2011 | 08:28 AM
Thore's Avatar
Yeah. Stock is 19ish.
Check for leaks or if you installed a boost control, may have to do some adjusting
Old Mar 27, 2011 | 08:29 AM
evoshawn20's Avatar
Yeah a stock evo should be at about 16 psi. And you can run a little more than that safley.
Old Mar 27, 2011 | 08:40 AM
Sanny632's Avatar
Hmm I'll have to search for leaks I bought the car as it sits I added a eve 9 Bov. Hmm maybe a boost controllerv
Old Mar 27, 2011 | 08:43 AM
evoshawn20's Avatar
if its staying at a steady 10 psi it doesnt sound like a leak. probably just need to turn the boost up
Old Mar 27, 2011 | 08:56 AM
Ginglingston11's Avatar
if everyone else is saying that he should be boosting 16-19psi on a stock car and hes only boosting 10psi...where do you get he needs to turn it up? hes loosing 6-9psi somewhere. it has nothing to do with a mbc
Old Mar 27, 2011 | 09:13 AM
Sanny632's Avatar
Well I looked under the hood for a mbc I cannot find one but I do see a Y vacuum coming off of the wastegate but I have to pull off the airbox to find out where it leads to but it seems that it goes to the intake tube it looks like there used to be on and now it is not here
Old Mar 27, 2011 | 09:57 AM
Piro Fyre's Avatar
Those vacuum tubes goes to a boost solenoid. I had this problem where I bought a brand new solenoid and hooked it up. My boost was also limited to 12psi when it was hooked up to the solenoid. I don't know if it has anything to do with an SES light but mine was on. Fixed it by buying an MBC and doing all the tubing myself. Tune the MBC to 20 and you should be good.
Old Mar 27, 2011 | 10:19 AM
Sanny632's Avatar
Is that solenoid a littlte bigger than a wallet rectangle shape? I think it is un plugged
Old Mar 27, 2011 | 01:01 PM
Sanny632's Avatar
I am going to attempt a boost leak test, is there a proper way to do this, or an easy way?
Old Mar 27, 2011 | 01:05 PM
vanilla2's Avatar
Search
Old Mar 27, 2011 | 08:06 PM
Sanny632's Avatar
It seems that it is my stock boost solenoid, I don't think it has the pills in place it looks as if someone added a mbc the removed it before selling the car now it only has 11 psi
Old Mar 27, 2011 | 09:58 PM
sparky's Avatar
You could remove the existing boost/vacuum hose assembly which may have the restrictor orifices(pills) removed and in its place install a new factory hose assembly(P/N MN 143555). This would be one option. There are a couple of other options as well.
Old Mar 27, 2011 | 10:00 PM
Sanny632's Avatar
I think I am gonna use a mbc I'll try that tomorrow
Old Mar 28, 2011 | 10:33 AM
Sanny632's Avatar
Ok so I capped nessary vacuum ports and used my AMS boost controller from my GSX now I started w it all the out and gradually turned it in. I was able to spike at about 16. When I get to about 14 it starts acting eratic the motor ... Stutters and the boost goes Dow to 11 and stays solid. Now it seems I do have a boost leak
