Need Help
Need Help
About a week ago I punched it in first and put the clutch in to go into second. Car would not go into second. If I push the clutch pedal down it goes down and comes back up, kinda feels soft and pulsates when i push the clutch in with the car started. I put the car in nuetral and coasted off the road. I started the car in first and it made a terrible schreeching noise and started rolling forward with the clutch pushed down. I got it moving and shifted without the clutch to get it home. If I pushed the clutch in and tried to go into gear with the car started it would lock me out and make a terrible noise.
Then today I bled the clutch . Started her up and wouldnt go into gear. Clutch pedal vibrated pretty bad when when being pushed in and coming up. I turned it off and just pushed the clutch pedal down 10-15 times. Started it up and it would go into gear and got it to move. As I released the clutch, the car shuddered much more than before. After 10-15 seconds with the clutch down and car in gear there are weird noises coming from the engine bay. If I put the car back in neutral and let off the clutch; then the car wont go back into gear with it running. But makes weird noises with the clutch pushed in. I am soo confused. Any advice?
