Best cams for stock IX turbo?
Old Apr 3, 2011 | 11:08 PM
LakerRaider's Avatar
I've done tons of searching, and still haven't found a direct consensus to a setup with full bolt ons and plans to stick with stock IX turbo. However, obviously gsc s2 and kelfords are the favorites. I even found most to say that s2 are best for IX, and kelfords for VIII, but still vague by not mentioning what turbo.
My goal is to max out the stock turbo with all the bolt ons I can get, and at this point, all I need is to buy an fmic, and install my 1000cc RCs, valvesprings and retainers that I have laying around. I have everything else . I plan not to upgrade my IX turbo and this is my DD. I currently have hks 272, but I want more power. I have the new hks 272 (10.8 lift)/278(11.0 lift) right here, but don't know if I should install them, As they are fairly new with not much data , let alone on how they would run on stock turbo. or get some s2 or kelford. God help! I just want to be finished with this car already...thanks in advance for any help.
Old Apr 3, 2011 | 11:12 PM
DormantBeast's Avatar
go with gsc s2's and u'll nvr look back, even if u do upgrade turbo's later on they will be able to give u the power ur looking for.
Old Apr 3, 2011 | 11:15 PM
How do think transient response is effected with the s2 on stock turbo?
Old Apr 3, 2011 | 11:28 PM
ct9asilver's Avatar
You need to talk to English Racing about the GSC's on a stock turbo thy run them a lot, but yeah the S2's are an excellent cam for a pretty good range of turbo's.
Old Apr 3, 2011 | 11:56 PM
LanEvo9MR's Avatar
sry for the op, but what spring and retainer would be the best match for mivec s2?
Old Apr 4, 2011 | 01:44 AM
JohnBradley's Avatar
GSC beehives and stockers, if its a motor meant to rev then throw in the retainer upgrade.
dyno sheets showing no loss of spool, response is hard to characterise on a dyno but I have never noticed it on the street-
https://www.evolutionm.net/forums/ev...370ft-lbs.html
Old Apr 4, 2011 | 08:13 AM
I have the hks singles w Manley retainers , they should work with the s2 right? I'm leaning towards the s2...I wish there were more threads about these cams with stock turbo
Old Apr 4, 2011 | 08:27 AM
asdfasdf128's Avatar
check out the s1 review here:
https://www.evolutionm.net/features/article.php?id=86
Old Apr 4, 2011 | 10:10 AM
Those springs will work great, not to worry on them.
There are actually a ton of threads starting the original-
https://www.evolutionm.net/forums/ev...tle-turbo.html
Some E85 stuff (both VIIIs and IXs)
https://www.evolutionm.net/forums/ev...t=stock+IX+E85
Should be a little reading there
Old Apr 4, 2011 | 10:40 AM
adam_79_2005's Avatar
When I still had the stock 9 turbo I ran kelford 272 cams with supertech dual valve springs and titanium retainers, I put down 365hp, and 345tq, I was very impressed.
Old Apr 4, 2011 | 10:50 AM
fantrman's Avatar
+1 for Kelford 272s
Old Apr 4, 2011 | 10:55 AM
NewEvolutionIX's Avatar
I have a set of evi ox GSC S2 cams with about 1000 miles max on it. PM me if interested
Old Apr 4, 2011 | 03:11 PM
pmd
Old Apr 4, 2011 | 03:19 PM
Baxtersevo's Avatar
I just posted this same question right after you about an VIII, lol
Old Apr 5, 2011 | 09:33 PM
now im thinking of getting s1s...i didnt know the lift was 11 and 10.5, this might be the safer way to go on stock turbo... idk
