i cant complain about my s2's they have worked great from my stock turbo to an Fp red and now on a 6262
Btw, for the GSC S2 owners mind to share what yr cams setting spec? Exactly according to GSC spec or your own spec?
Quote:
they idle way better than the Cossies, they are less expensive, they make more power. All in all I am going to have to go with Yes. Originally Posted by bbyevo8u
are the s2's really that much better then the m2's?
Quote:
any back to back test done on this?Originally Posted by JohnBradley
they idle way better than the Cossies, they are less expensive, they make more power. All in all I am going to have to go with Yes. Evolving Member
little off topic but same question i am running a red arp studs and will upgrade springs but debating between the s2's and the fp4r's i am running gsc s1's now but going to upgrade
whtrice
close
- Join DateJun 2006
- LocationSacramento
iTrader Positive Feedback100
iTrader Feedback Score(6)
Liked:58 Times in 52 Posts
I have Cossies (M2's) myself. I think I probably had one of the first sets installed back in '06 on my IX RS. They have performed well for me over the years and I made good power with them. Mine also idled well and you could vaguely tell I had cams thanks to Bryan (Razorlab) who tuned me.
That said... I have seen many have good success with the S2's as well. I did upgrade my springs at install and glad I did. I personally think anytime you install cams with 11 mm of lift or higher it is a good idea. Kelfords are a good choice too. Nice to see we have so many choices now. I think just get your best deal on either of the ones mentioned and you will
be fine.
be fine.
