replacing BOV?
Old Apr 16, 2011 | 07:46 PM
403evo's Avatar
replacing BOV?
had an HKS super sequential valve, and its now in the garbage. what can i replace it with? dont wanna go back to a stock one, but not sure what to buy or if it'll fit. heres a list of my mods, any recomendations would help. thanks.
2004 Mitsubishi Lancer Evolution VIII, GSR, SSL equipped, lightly modded with AMS Intake, Halman Evolution RX mbc, MUSE LICP, HKS BOV (now in the garbage), Ported Exhaust manifold, Ported Evo IX turbo, Ebay O2 housing, Megan racing 3" TBE ( no cat), Walbro 255 fuel pump, PTE 1000cc injectors, Stage 2 exceddy clutch with lightened flywheel, short shift kit, was tuned for 350WHP
Old Apr 16, 2011 | 10:06 PM
awdordie's Avatar
Im running the synapse on my honda setup. Alot of evo owners on here say they are great haven't gotten the honda done yet to know for sure tho. Can I ask y ur hks on ended up trashed, I know many people say they are junk but the one on my evo has held up well.
Old Apr 17, 2011 | 06:50 AM
sparky's Avatar
I like the stock metal valve ever so slightly crushed. I realize that the panache factor would be limited....but in Cali this is not such a bad thing to be stock appearing. As a practical matter, for the boost levels that you can probably run with a stock turbo on 91 octane pump gas, a crushed or modded stock metal DV should be up to the task.
Old Apr 17, 2011 | 07:16 AM
phrequenc's Avatar
i dont think there is a benefit of changing your DV to something with noise, buy a stock IX and call it a day, its metal and works much better .
Old Apr 17, 2011 | 07:18 AM
milford's Avatar
synapse DV...period.
Old Apr 17, 2011 | 08:38 AM
phrequenc's Avatar
im going by what other people have said, my car is still mostly stock. scared to change out bov
Old Apr 17, 2011 | 09:10 AM
dastallion951's Avatar
well to add my 0.02 i had an hks ssq before( used car came with it), after time im now running a greddy type rs, not a bad bov, a little surge at high rpm low boost, but holds 24psi to redline just fine, plus its adjustable. If i could go back I would either buy, a synapse like someone posted, or either an aps twin vent, or a forge dv....any of those are just as good as the stock ix metal dv....good luck
Old Apr 17, 2011 | 09:27 AM
403evo's Avatar
HKS bov wouldnt hold any pressure above 23-2500 rpm, and ive been looking at bov's but some of them look like they need to be welded in and not clamped in like my old one.
ill prob just get a stock IX and call it a day, thanks guys
Old Apr 17, 2011 | 09:53 AM
dude unless your uicp is flanged for em, there all stock like bolt on with clamps....
Old Apr 17, 2011 | 09:56 AM
shifthard's Avatar
I went with .samco diverter valve. Works great. It's a piston style and not a diaphragm like greddys or hks.
Old Apr 17, 2011 | 05:15 PM
403evo's Avatar
just ordered up a IX stocker. cant wait till it comes in.
Old Apr 17, 2011 | 05:28 PM
milford's Avatar
my 9 valve started opening at 26lbs with a crushed top...these things suck.
Old Apr 17, 2011 | 05:34 PM
Pal215's Avatar
lmfao too late for OP, i have a synapse, try and make this thing leak.
Old Apr 18, 2011 | 04:18 PM
403evo's Avatar
on the bright side thats the first bad thing ive heard about them. hope this lasts me a while
Old Apr 18, 2011 | 04:36 PM
phrequenc's Avatar
i only want to change the valve on my ix becuase i want pshht, everyone says thats bad for this car though.
