Rebuilding my Evo IX
Old Apr 19, 2011 | 01:24 AM
SHADOWPHANTOM's Avatar
I have an 2006 Evo IX I am rebuilding the engine because of water damage to the vehicle. The parts I am using are as follows:
AMS Stage 2 rebuild kit
Tomei 260 cams/cam gears
Tomei ARMS turbo
Greddy V-manage
Still trying to find the right fuel injectors but I haven't made a decision on them yet. My question is how much power can potentially be made with this set up?
Old Apr 19, 2011 | 01:44 AM
adam_79_2005's Avatar
I'd probably go at least 272 cams instead of 260 Tomei cams, you mentioned Tomei cam gears aswell, the EVO IX has mivec on the intake side so it would be only the exhaust cam gear that you would purchase. As for injectors, precision 1000cc should be more then enough, as for power, I'm not really familiar with that turbo, but with a good tune and under the assumption that Tomei turbo is fairly bigger then stock I'd guess around the 400hp marker for sure, but do look into gsc s2 cams, kelford 272.
Old Apr 19, 2011 | 02:20 AM
LGshow19's Avatar
Why not look at a FP turbo or BBK turbo? I havent heard too many good things about the Tomei line up.
A walbaro and 1k injectors will be plenty if your running 93oct or something of that nature.
Old Apr 24, 2011 | 09:32 PM
Sounds good I will look into those options and hopefully I will be rolling in late June or July pending parts and installation.
Old Apr 24, 2011 | 09:47 PM
LGshow19's Avatar
Let us know how it goes
BlackEight
Jan 23, 2012 07:54 PM
Dosagex
29
Mar 28, 2011 09:33 AM
dirtylilevo
21
Nov 25, 2010 10:13 AM
jdowd
23
Jan 23, 2010 09:56 PM
dmotors
21
Sep 29, 2009 03:29 PM
