Engine Bay Noise: "Tick" Coming from a pump (I think...)
Old Apr 21, 2011 | 07:30 PM
EVO KiiD's Avatar
So after recording mine and listening to them both again they both sound really similar. If you find any good info please post back as I would be very interested to hear any and all info about this issue. I want to fix mine without spending an arm and leg thanks in advance
http://s235.photobucket.com/albums/e...421_181309.mp4
Old Apr 21, 2011 | 10:04 PM
barneyb's Avatar
I'm kinda hazy on this (I have an 8), but from what I remember of an old thread, this turned out to be the timing belt rubbing on the crank angle sensor. Anyway, people who took this to the dealer under warranty got it fixed and it had to do with the timing belt. So, you could talk to the Mitsu shop and maybe find out what their repair is.
Old Apr 23, 2011 | 09:15 AM
EVO KiiD's Avatar
So I think I found the real problem its the large bracket itself that holds the idler pulley and other pulleys the bracket bolts to the engine mount I think. I guess it has been slightly changed to give a different angle or spacing or something. I'm still doing research on this but that would make sense. People in the past that have had this issue when the cars were brand got theirs fixed under warranty and the sound comes back. In more up to date posts the bracket is the culprit and has been changed to fix this issue. Most people change the bracket, pulleys, tensioner, timing belt and crank angle sensor blade. No mention about the balancer belt or water pump but while in there it would be a good idea to change those as well. I want to do more research about the bracket itself actually being different, I'll post my findings. I found a sticky on here about it, I'll post that up. Good luck to all 9 owners with this issue.
Old Apr 23, 2011 | 09:17 AM
EVO KiiD's Avatar
Here's the link to the sticky on here, good luck again to everyone
https://www.evolutionm.net/forums/ev...elt-video.html
Z_Lancer_Man
12
Feb 13, 2012 05:27 PM
Protostar1
11
Dec 28, 2011 07:31 PM
sc_s13
Dec 5, 2011 11:55 AM
binky
Automotosports - Illinois
11
Mar 6, 2010 11:08 AM
HighPsi134
34
May 23, 2005 04:26 PM
