No barb on stock IX turbo?
Heres a question for you guys and girls...
I was helping a friend do a boost leak test last night on his 06 IX. He did buy the car used and supposedly it had a red on it before it was sold. Now it is known to have a stock IX turbo. It does appear to be stock to me anyway.
When i was attaching my tester to the turbo inlet i did notice one thing though. The inlet doesn't have a barb on it like my IX turbo does or even my VIII. I could tell immediately when after cranking down the hose clamp i could still move the coupler around a little bit and then eventually pull it off. It wouldn't stay on on the turbo with more then 20psi like this. It would just blow off. This was with a T-bolt clamp too.
Anybody s stock turbo like this? Or is this a sign of a FP cold side or a BBK? It doesn't have any aftermarket badges or plates on it. Just the standard TD0...yada yada 16GC or what ever.
Thanks for any info!
Ethan
Ethan
the non-surge ported fp turbo's that i have seen = grn, red didnt have the barb on the inlet like a oem 8/9 front cover.
i honestly cant remember if my surge cover black has a barb as well..!?!
Interesting. So i guess what id like to figure out is weather or not the red is still on the car. The car pulls pretty hard as it is. Even though we found a decent boost leak last night. (Bad weld on UICP)
Is there any other signs i can look for to see weather or not its a red? Like i said it doesn't have the FP name plate or the FP stamp on the cold side. That i can see anyway. Is the compressor wheel visibly different then the OEM wheel? blade count etc?
Another weird thing that I noticed is when logging the car the IDC's were 98% after peak boost. It is believed that the car has PTE 1000cc's. The scaling in the ROM is 660 or something like that. But that all depends on who dialed them in so its not too far off.
My car also has PTE1000cc's with a stock IX turbo and very similar setup to his car cams SS o2 housing etc etc. My IDC's are at most 60% when i was touching 25psi. Granted his boost was set to around 28psi spike so this will come into play for sure....but 40% for a couple of psi?
Thanks for the response Aby
I thought so too.
I tried looking last night and i didnt see any FP stamp on the falt part of the compressor side. I looked pretty hard too. But i dont see why a stock turbo would have that barb machined off. Whats the point of doing that anyways?
have you thought about doing a 3rd gear pull and putting it into virtual dyno? that might could help determine if its a stock turbo or fp one, also checking out the timing/fuel maps could help. just a thought
Ive pasted a log below. The reason i was even questioning weather or not it was a green or red was because of the logs. Look at the load 320? And the IDC's of 98% on PTE1000cc's? This is at about 28psi btw.
Ive also attached a VDR of a different log that didnt have a shift in it. Its certainly up there in power and this was with a boost leak that we found the other night. And a weird turbo sputtering issue.... It certainly feels fast but didnt seem a whole lot different then may car which is coming in around 400hp and 390tq.... I have almost same setup with stock fmic and stock IX turbo....Its all about the area under the curve though so i guess thats what i could be feeling as far as difference.
| TPS | RPM | TimingAdv | KnockSum | KnockVoltage | LoadCalc | InjPulseWidth | InjDutyCycle | AFRMAP |
| 97.64705882 | 3937.5 | 19 | 0 | 1.053 | 191.4115287 | 9.472 | 31.32666667 | 11.68695652 |
| 100 | 4000 | 16 | 0 | 1.2285 | 211.1339756 | 10.496 | 35.26 | 11.33493976 |
| 100 | 4062.5 | 13 | 0 | 0.975 | 226.3415066 | 11.52 | 39.3 | 11.06823529 |
| 100 | 4125 | 13 | 0 | 1.0335 | 244.7826898 | 12.544 | 43.44666667 | 11.00350877 |
| 100 | 4187.5 | 11 | 0 | 1.014 | 266.4093861 | 13.568 | 48.05333333 | 10.87630058 |
| 100 | 4281.25 | 9 | 0 | 0.9165 | 287.6847074 | 15.104 | 54.28 | 10.752 |
| 100 | 4375 | 8 | 0 | 1.56 | 308.9058839 | 15.104 | 55.06666667 | 10.8137931 |
| 100 | 4531.25 | 7 | 0 | 2.2815 | 326.4537579 | 17.408 | 64.82666667 | 10.752 |
| 100 | 4500 | 7 | 0 | 2.418 | 321.4468084 | 18.432 | 70.56 | 10.752 |
| 100 | 4625 | 6 | 2 | 1.8525 | 359.749177 | 18.944 | 74.49333333 | 10.87630058 |
| 100 | 4781.25 | 7 | 3 | 2.1645 | 352.645928 | 19.2 | 76 | 10.8137931 |
| 100 | 4843.75 | 7 | 3 | 1.1505 | 339.9236501 | 18.688 | 76.40666667 | 10.87630058 |
| 100 | 4937.5 | 7 | 3 | 1.872 | 344.9884834 | 18.432 | 76.8 | 10.87630058 |
| 100 | 5062.5 | 7 | 3 | 2.0865 | 339.9236501 | 18.432 | 78.72 | 10.87630058 |
| 100 | 5187.5 | 7 | 2 | 1.677 | 337.096556 | 17.92 | 77.93333333 | 10.93953488 |
| 100 | 5281.25 | 7 | 2 | 1.8135 | 336.9511132 | 17.92 | 79.8 | 10.93953488 |
| 100 | 5406.25 | 7 | 2 | 1.365 | 333.9438097 | 17.92 | 81.66666667 | 11.00350877 |
| 100 | 5500 | 7 | 2 | 0.8775 | 332.002276 | 17.664 | 81.88 | 10.93953488 |
| 100 | 5625 | 7 | 2 | 0.975 | 327.0534387 | 17.408 | 82.05333333 | 10.93953488 |
| 100 | 5718.75 | 7 | 2 | 1.3845 | 319.1567697 | 17.152 | 82.63333333 | 11.00350877 |
| 100 | 5906.25 | 8 | 2 | 0.8385 | 320.7398547 | 16.896 | 82.72 | 11.06823529 |
| 100 | 5937.5 | 8 | 2 | 1.17 | 320.1512391 | 16.896 | 84.04 | 11.06823529 |
| 100 | 6031.25 | 8 | 1 | 1.7355 | 320.5927008 | 16.64 | 84.5 | 11.06823529 |
| 100 | 6062.5 | 8 | 1 | 2.223 | 315.7327959 | 16.896 | 87.56 | 11.06823529 |
| 100 | 6218.75 | 9 | 0 | 2.3595 | 315.585642 | 16.64 | 86.66666667 | 11.06823529 |
| 100 | 6312.5 | 10 | 0 | 1.5405 | 307.3796399 | 16.384 | 87.04 | 11.13372781 |
| 100 | 6406.25 | 10 | 0 | 2.3205 | 305.7186782 | 16.128 | 86.52 | 11.06823529 |
| 100 | 6468.75 | 9 | 2 | 1.716 | 304.1426139 | 15.872 | 87.21333333 | 11.2 |
| 100 | 6625 | 9 | 2 | 1.56 | 304.2915197 | 15.872 | 87.21333333 | 11.2 |
| 100 | 6687.5 | 9 | 1 | 2.34 | 300.8668212 | 15.616 | 87.84 | 11.26706587 |
| 100 | 6781.25 | 9 | 1 | 1.8525 | 295.9196126 | 15.616 | 88.65333333 | 11.26706587 |
| 100 | 6875 | 10 | 0 | 1.5405 | 297.7022609 | 15.36 | 88.4 | 11.33493976 |
| 100 | 6937.5 | 10 | 0 | 1.9695 | 294.9629002 | 15.36 | 89.2 | 10.51173184 |
| 100 | 7031.25 | 10 | 0 | 1.5015 | 291.8379727 | 16.128 | 94.92 | 10.57078652 |
| 100 | 7093.75 | 10 | 0 | 1.677 | 292.2595934 | 16.128 | 95.76 | 10.57078652 |
| 100 | 7187.5 | 10 | 0 | 2.184 | 288.8190695 | 16.128 | 97.02 | 10.63050847 |
| 100 | 7250 | 10 | 0 | 1.443 | 293.628109 | 15.872 | 96.30666667 | 10.63050847 |
| 100 | 7343.75 | 10 | 0 | 1.3065 | 290.3179497 | 15.872 | 97.13333333 | 10.69090909 |
| 100 | 7406.25 | 10 | 0 | 1.3065 | 290.3179497 | 15.872 | 98.37333333 | 10.69090909 |
| 100 | 7437.5 | 10 | 0 | 1.677 | 287.1129094 | 15.616 | 98.00666667 | 10.752 |
| 100 | 7562.5 | 10 | 0 | 1.482 | 283.8710295 | 15.616 | 98.00666667 | 10.8137931 |
| 100 | 7625 | 11 | 0 | 1.95 | 280.5916713 | 15.104 | 96.36666667 | 10.87630058 |
| 100 | 7656.25 | 12 | 0 | 1.9695 | -8.807850883 | 11.52 | 76.5 | 11.40363636 |
| 30.19607843 | 7968.75 | 36 | 0 | 1.6185 | -9.921554084 | 0 | 0 | 12.62818792 |
| 26.66666667 | 7968.75 | 38 | 0 | 2.106 | 186.9228623 | 4.096 | 26.98666667 | 11.40363636 |
| 93.33333333 | 7625 | 28 | 0 | 1.3065 | 215.8859272 | 10.24 | 64.53333333 | 11.06823529 |
| 100 | 7718.75 | 17 | 1 | 2.0085 | 288.7890244 | 13.312 | 78.69333333 | 10.28196721 |
| 100 | 5718.75 | 8 | 0 | 1.833 | 308.6723863 | 17.92 | 89.6 | 10.17081081 |
| 100 | 6062.5 | 9 | 0 | 1.599 | 317.739326 | 18.176 | 92.77333333 | 10.17081081 |
| 100 | 6031.25 | 9 | 0 | 1.4235 | 314.7041258 | 18.176 | 92.3 | 10.22608696 |
| 100 | 6125 | 9 | 0 | 1.521 | 310.2139962 | 17.92 | 91.46666667 | 10.22608696 |
| 100 | 6156.25 | 9 | 0 | 1.755 | 314.7041258 | 17.92 | 92.4 | 10.22608696 |
| 100 | 6218.75 | 9 | 0 | 2.0865 | 310.3499536 | 17.664 | 92 | 10.22608696 |
| 100 | 6281.25 | 10 | 0 | 1.326 | 310.3499536 | 17.408 | 91.12 | 10.22608696 |
| 100 | 6312.5 | 10 | 0 | 1.599 | 307.3944889 | 17.408 | 92.02666667 | 10.28196721 |
| 100 | 6375 | 10 | 0 | 1.56 | 304.2690951 | 17.152 | 91.12 | 10.33846154 |
| 100 | 6406.25 | 10 | 0 | 1.4625 | 304.1316436 | 17.152 | 92.01333333 | 10.33846154 |
| 100 | 6468.75 | 10 | 0 | 1.638 | 306.0883506 | 17.152 | 92.46 | 10.39558011 |
| 100 | 6531.25 | 10 | 0 | 1.8915 | 305.9501398 | 17.152 | 93.8 | 10.39558011 |
| 100 | 6562.5 | 9 | 3 | 2.0865 | 305.8119289 | 17.152 | 94.24666667 | 10.39558011 |
| 100 | 6625 | 9 | 3 | 1.9695 | 301.2473774 | 17.152 | 94.69333333 | 10.39558011 |
| 100 | 6656.25 | 9 | 3 | 1.6575 | 205.0313275 | 16.896 | 93.72 | 10.51173184 |
| 45.88235294 | 6718.75 | 13 | 13 | 2.106 | 38.41157203 | 4.608 | 25.08 | 11.83396226 |
just by looking at the load there is no way thats a stocker, ive still got the IX turbo as well, yes awhp and cams can have an effect to it i know but im pushing 307 awhp and like 250 tq (90 octane is the highest i get and other reasons lol) and my load hits no higher then like 240, ill have to double check a wot run, but get a full mod list or as best you can and ill try not to compare apples with oranges
who tuned the car as well, jw....see a few things that indicate boost leak too (as youve mentioned lol) but your table's will tell you more about it
Blacksunset. Like i said we both have almost identical setups except for im running the stock FMIC and he has some aftermarket one. So I know for a fact that the turbo i put on my car is a stock IX turbo. He was told that his is a stock one but previously had a red.
I logged his car and my car on the SAME day only 20 min apart. Ran both through my VDR program with the correct parameters and his log showed 450+ for both tq and hp where my car was around 400hp and 390tq.
Im curious as to what in the logs set you off to a boost leak? It did infact have a leak for those logs.
Here is the VDR plot of his car. FP Red?
i never meant to offend you by all means, but from your loadcalc (shows more towards the end then anything) it goes into the negatives within a 300 rpm gain, normally wouldnt do that but it it reflects in the load thoughout as well, pull on of your wot logs and compare your load with the one above, (its very minor, but still noticed though out other portions not only in the load) but when your at 7968 your AFR is at 12 while the whole run was around 10 or so showing an improper mix (normally caused by boost leaks, minor or major and the maf trying to make the difference up by sucking less air more fuel, logging boost is another good way to tell becuase it will spike at that point) then you let off and started the run from 5k which was at a 10 afr as well and continued up to 6700 rpms and it went to 11 afr, your afr should run similar if not the same for each run and given how the load is, if its off due to a boost leak itll show a gain in afr and wont match the previous rpm's or engine load (shouldnt match completely but shouldnt be off by more then 2-4
he is deff putting down some good numbers,
what octane is he running and a mod list will deff help sort though some stuff as to why he has a huge power gain over you, but its possible to squeeze out 500 on the stocker on e85 maybe some high octane race gas too but one thing is for sure, check the inlet of the turbine and measure both yours and his, if there both stock then they should produce the same numbers, unless ported which is a possible for sure in this case, ill go with a ported turbine more then green or red,
