AEM Boost Solenoid clicking *Vid inside*
Old May 2, 2011 | 02:33 PM
flymx771's Avatar
Well I've been hearing an odd clicking sound the past few days and finally got the time to try and locate it. Turned out to be coming from my 5 month old AEM boost solenoid. It seems to be doing this intermittently. In the video the engine is off and the key is in the on position. So my question is, is the solenoid bad? And do you think I should contact AEM for a replacement or is there something I can to do try and fix this thing? Thanks in advance guys.
http://www.youtube.com/watch?v=7lH-IWXHZ2k
Old May 2, 2011 | 02:44 PM
awdturbo8's Avatar
I have the same exact issue for the past 6 months.
Old May 2, 2011 | 07:35 PM
diablo1's Avatar
Same here, I've had this sound for over a year.
Old May 2, 2011 | 07:45 PM
flymx771's Avatar
It holds boost just fine too. No creep or anything. Same for you guys?
Old May 2, 2011 | 07:51 PM
Wheatley's Avatar
That just sounds like the solenoid working. Depending how your boost control map is setup you can adjust the table so the solenoid isn't trying to operate in those load cells. I believe it is mentioned on the aem forums on the advanced boost control thread. That's how I learned what mine was and how to adjust the table so it wouldn't do it any longer.
Old May 2, 2011 | 07:57 PM
Wheatley's Avatar
I went and double checked my map since I havent looked at it in several months.
click
boost control
the first option should say boost control click that again
The table should be the duty cycle for the solenoid. Everything in vacuum across my entire rpm is 0.00 depending how your boost control was setup this could be 0 or 100. You don't need the solenoid operation when its in vacuum or anything under your wg spring for that matter but to be safe I just have it off in vacuum and operating during boost. If you didn't tune your own car I wouldn't recommend fooling around with the boost control settings.
Old May 2, 2011 | 08:16 PM
flymx771's Avatar
click
boost control
I didn't setup the solenoid myself but I'll check it out tomorrow. Seems odd to me that my tuner would have set the solenoid to being operating while in vacuum though.
Also, this still doesn't explain why it would do this intermittently...unless it always has been operating, then all sudden got louder...which would lead me to believe that there is a problem.
I don't wanna put you through the trouble of doing this, but it would be greatly appreciated. Would you set your duty cycle to 100 during vacuum and see if your solenoid does the same thing? That would really help me out man.
fast3voviii's Avatar
They all do that
Old May 3, 2011 | 06:45 AM
Wheatley's Avatar
Mine clicked at anything over 0. That's the duty cycle table telling the sol to operate. A lot of people will set that table to 50 across the board and forget to clear the vacuum portions. It might not be the problem bit it only takes a second to verify. My sol doesn't click at idle.
jetxjosh
Evo X How Tos / Installations
Mar 12, 2016 05:39 PM
Babs
AEM EMS
Jun 28, 2014 06:48 AM
TurboTravis
AEM EMS
Sep 2, 2010 01:29 PM
EvoIXMR
Aug 4, 2008 08:06 AM
ElectricEvoIX
Jan 21, 2008 07:28 AM
