FP Red (84mm) users get in here plz...
Old May 3, 2011 | 06:08 PM
GBAILEY472's Avatar
Curious to know why some users have no issuses with surge and others need to run external wastegate ? what is the secret recipe for this turbo ?
Old May 3, 2011 | 06:24 PM
RSMike's Avatar
external wastegates do not cure surge.
i'm assuming you mean recipe, not receipt.
i went from a stock comp housing red which surged horribly to the 84mm cover. Zero surge issues since.
Old May 3, 2011 | 06:35 PM
GBAILEY472's Avatar
like this ? does boost pressure have an influence also ?
Old May 3, 2011 | 06:55 PM
RSMike's Avatar
yup like that.
do you know how to read compressor maps?
higher boost pressures at lower rpms has a higher chance for surge.
anti-surge compressor housing greatly reduces or eliminates surge by moving extending the left hand side of the compressor map
Old May 3, 2011 | 07:36 PM
GBAILEY472's Avatar
during spool you can hear a whooop whhoop whooop, and in 5th it shakes the whole pretty bad.
how do I get rid of that ?
at 3 sec's in
http://www.youtube.com/watch?v=qlz7wRVxZmc
Old May 3, 2011 | 07:45 PM
RSMike's Avatar
i'm not sure if thats surge.
it does sound like it though.
you shouldn't get it when you change into the next gear, like you did in your video (where it still sounded like surge)
what BOV are you running?
is your car tuned for the FP Red?
Old May 3, 2011 | 07:49 PM
GBAILEY472's Avatar
Tial Bov, tuned yes. but my tuner say's I need an external wastegate and this is where I disagree with him. This is why I am here trying to get info form Fp red users..
Old May 3, 2011 | 07:52 PM
RSMike's Avatar
have you tried reducing the preload on the wastegate actuator to make it spool later?
and do you have adjustable cam gears?
are they set in 0,0 or something different?
Old May 3, 2011 | 07:57 PM
GBAILEY472's Avatar
I have installed right now a 18psi, and also have the 25psi (BINB) not yet installed. whick should I use ?
Old May 3, 2011 | 08:03 PM
ROGERV's Avatar
Do you have any lines tee in with the bov line?
I get surge on 4th or 5th if I get on it at low rpm, I now just down shift to avoid it.
Old May 3, 2011 | 08:20 PM
RSMike's Avatar
you get surge in a 84mm covered FP Red?
i can get full boost @ 3400rpm with no surge on my 2.3
Old May 4, 2011 | 07:22 AM
GBAILEY472's Avatar
adjustable cam gears, No. set at 0,0. I have no idea.
Old May 4, 2011 | 08:53 AM
BEISSEN's Avatar
Dont boost right into 5th you need to be high up in the RPM Band to boost in 5th thats why you surge. I think your tune could be off and External WG wont do a thing for this.
Old May 4, 2011 | 11:02 AM
raasfaas's Avatar
hmmm, a little weird that you are getting surging with the 84mm cover...I originally had on the 64 and mine sounded exactly the same as yours...I installed the 84mm a month or so ago and cured my surging totally.
Like RSMike said, maybe you need to try reducing the preload on the actuator...how much psi are you seeing now on the 18# actuator without any boost controller in the line?
Old May 4, 2011 | 12:41 PM
GBAILEY472's Avatar
Car sometimes peaks 30 and drops to ~26 with EBC controller. last dyno run was 498awhp at 28psi, but that run above was tuned down at ~ 420awhp
