Tcase Fluid Color
Tcase Fluid Color
I recently changed my tcase and rear diff fluid to amsoil svg 75w 90. After changing the fluids for the first time i noticed that the tcase fluid was shiny had like a silver shine to it. The rear diff the fluid came out clean though no shaving or anything. I have now switched back to the diaqueen fluids and will be checking the tcase fluid next change. Just wondering if anyone else has had the same problem cause im concerned my tcase may be on its way out?
Input would be appreciated
thanks
thanks
Thanks for the info guys, i didnt save the oil but after the next change i will to have it looked at. My car is pretty much all stock other then a tune currently running 24 psi. Would a thinker tcase oil be recommended or should the diaqueen be fine to use?
Sorry to tell you this, I recently had the death whine, and my oil was very silver. You might want to start saving some $. Jack's Transmissions in Colorado did a Stage 2 rebuild for me, I must not have had enough oil in it when I took it around the block, it immediately whined at 45 mph. They redid it AGAIN, no cost to me.
