Modifying the stock turbo...
Old Dec 21, 2003 | 03:28 AM
alex_alex's Avatar
does anyone know about ways to modify the stock turbo in a way thats relatively undetectable?
a couple of the LA guys were talkin about turbonetics having something like that, but im not sure what it is .
Old Dec 21, 2003 | 07:47 AM
bishiboy's Avatar
It's turbochargers.com
http://www.turbochargers.com/Turbos/...EvoUpgrade.htm
Old Dec 21, 2003 | 08:11 AM
Jev3gs's Avatar
But what type of power gains can you except with the modified turbo though?
Old Dec 21, 2003 | 12:56 PM
Erik@MIL.SPEC's Avatar
Throw a 10.5 exhaust housing on there. It will help things. I plan on getting a TME turbo, once I get an Evo in the next couple of months. It should look stock except for different numbers on the turbo.
Old Dec 21, 2003 | 01:43 PM
BPAuto's Avatar
Silver Sponsor
That upgraded turbo is rated up to a max of 500HP. Not bad for $825.
__________________
"Let us help you build your JDM dream!"
www.bulletproofautomotive.com
The Real JDM - Interactive (blog)
Email: sales@bulletproofautomotive.com
Direct North American Dealers for Voltex, Mines, Varis, First Molding, HKS Kansai, Cusco, HKS, Advan, Volk, Ings+1, C-West, Work, and so much more...
Old Dec 21, 2003 | 01:48 PM
954DRGSR's Avatar
Do a search on this - I remember reading a post where someone had some bad results w/ the mod done by turbochargers.com . . . . . . .
Old Dec 21, 2003 | 01:53 PM
MalibuJack's Avatar
Hmm.. I'll have to research this a bit more.. I'm a wholehearted believer in keeping as many of the components as stock as possible. I really like the twin scroll design. I'm more than willing to try out the upgrade as long as their aren't any horror stories about it. FWIW After upgrading the JIC manifold, upgraded Turbo, and O2 housing, Its cost would be approaching the cost of an aftermarket upgrade. So you have to weigh the benefits.. I want to try to avoid the the compromises of going with a larger aftermarket turbo setup. HOWEVER after adding it all up, You might want to make your own decision. The only issue with a completely new turbo setup (Like the HKS) is the additional supporting mods that come with the territory. (which most who would consider this would have already made)
Hope this helps..
Old Dec 21, 2003 | 02:00 PM
MalibuJack's Avatar
Lowering the mass of the turbine and impeller wheels, clearancing the hot side of the housing, porting the wastegate poppet.. anything that will increase the maximum flow of the turbo, along with reducing restrictions and friction in the hot side will improve the stock turbo. Apparently that is what their upgrade does.
For a straight bolt-on, there is always the TME turbo (Evo 6.5) or whichever one has the Titanium components..
Not sure what else to suggest, not all of these mods are considered cost effective for the gains you can make. But if your in a racing class where modifications are strictly regulated, then you need to use a housing that is visually indistinguishable from stock, or the JDM part which is identical externally.
Be warned.. some major events will require an inspection and possible disassembly if you win, or have a significant advantage to otherwise similar (Same) cars..
Old Dec 21, 2003 | 03:10 PM
David Buschur's Avatar
I really like Turbocharger.com but......
We tried one of the upgrades on our EVO. DOES NOT work. I don't think they have anything new and if this is still the first one they released then it should not be for sale.
If you guys from Turbochargers see this, don't get pissed.
David Buschur
www.buschurracing.com
Old Dec 21, 2003 | 03:32 PM
n00dle's Avatar
Dave, don't you miss the ingenuity of PROTurbo (circa 1993)
Old Dec 21, 2003 | 03:41 PM
mhgsx's Avatar
I inquired about the Turbochargers.com upgrade 2 weeks ago. They said that they were still working on it and wasn't available for sale yet.
Old Dec 21, 2003 | 06:05 PM
Fourdoor's Avatar
https://www.evolutionm.net/forums/sh...tock+and+turbo
In my opinion this is the absolute best idea I have seen for anyone wanting to keep the stock (or near stock) turbo setup to get a substantial gain in top end power.
Keith
Old Dec 21, 2003 | 06:09 PM
Chris in HB's Avatar
The Turbonetics rebuild is done differently - I believe the details are on their website and also on the SoCalEvo.net boards. I know they install a ball-bearing center section and it costs $500 w/core exchange.
alex_s817
Feb 2, 2016 11:25 AM
tscompusa
Jul 27, 2014 07:03 PM
alex_s817
Jun 16, 2014 06:18 PM
alex_s817
20
Apr 25, 2013 05:03 AM
ThyPunko_PR
23
Feb 20, 2006 06:43 AM
